Old 01-07-2005, 12:46 PM
gbaude1 gbaude1 is offline
Unhappy Accessing Fuse Box
I need to replace the fuse for the heater fan and I cannot get into the fuse box on the passenger's side. Can someone please tell me how to remove the access cover before I break it?
Old 01-07-2005, 06:09 PM
grfnkl's Avatar
grfnkl grfnkl is offline
Send a message via AIM to grfnkl
you just have to pull on it using the finger tab in the fuse panel door, sometimes they are tight and won't come out easy, you could always use a screw driver along the edge on the side that would be closest to the seat and try to pry it up enough to pop it off.
Old 01-07-2005, 07:06 PM
Forkliftguy's Avatar
Forkliftguy Forkliftguy is offline
Re: Accessing Fuse Box
Yeah, they are usually in there real good because they rarely ever get opened on the right side, most people don't even know that there is a fuse panel there. You have to pull pretty hard, it will feel like it's going to break but it shouldn't.
Old 01-08-2005, 06:45 AM
Thumbs up Re: Accessing Fuse Box
Thanks for the help, gentle use of the screw driver worked just fine! Was able to put in the new fuse and everything works great. I really appreciate the help.
