Old 01-07-2005, 12:08 PM
babuhr babuhr is offline
IAC valve? '97 S-10
I have a 97 S10 (4.3, 4WD, 5-spd). When I take it out of gear and coast, the RPMs rise and fluctuate rather than dropping down to an idle. This will continue until I bring the vehicle to a complete stop. I pulled the IAC and made sure the pintle was set to 28mm. It worked for a while, but now the problem is back. Any ideas? Thanks.
Old 01-07-2005, 02:26 PM
busa_4 busa_4 is offline
Re: IAC valve? '97 S-10
check the tps sensor. also check to see that you dont have any vacuum leaks.
Old 01-08-2005, 09:03 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Did you clean the iac and the hole it fits into with carb or TB cleaner?
1995 Factory Blazer Service Manual for sale, PM if interested.
