Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-07-2005, 12:00 PM
Bob Shaw Bob Shaw is offline
97 Jimmy front suspension
I changed to a smaller backspacing rims and found that the front passenger side tire now sticks out about 1 1/2" farther from the fender than the driver side. Is this normal? All the rims are the same. The frame is not noticably bent. The A frames, etc. on the driver side may have been replaced. Could they have swaped with a different year or model?
Bob Shaw
Old 01-08-2005, 10:19 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 97 Jimmy front suspension
Yip, it is normal.
That is why you don't change the back spacing.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-09-2005, 08:02 AM
Re: Re: 97 Jimmy front suspension
Originally Posted by BlazerLT
Yip, it is normal.
BlazerLT
I wanted to widen the distance between wheels for stability and it worked. With new rims, I moved all the wheels out about 2" each. That is when I noticed the difference in the front wheels.
Are your front wheels off set too? Is your passenger side closer to the side of the fender than the driver side wheel?
Bob Shaw
Old 01-09-2005, 01:15 PM
BlazerLT's Avatar
AF -Advisor
Yes, they are offset like that, prefectly normal.
Also, remember, it is illegal to have the tires outside of the wheel well.
Old 01-09-2005, 02:58 PM
WOW You are the first to say it is normal. Thanks for the info.
1) You are correct
2) not a law that is rigidly upheld down here
3) that is why I added fender flares.
Bob Shaw
Old 01-09-2005, 06:45 PM
BlazerLT's Avatar
AF -Advisor
Ah, yes, fender flares will make it perfectly legal.
Old 01-10-2005, 08:34 AM
They also keep the mud out of your arm pit when you make a right hand turn and have your arm hanging out the window.
Bob Shaw
Old 01-10-2005, 10:58 AM
BlazerLT's Avatar
AF -Advisor
Bob Shaw
Tehehehe
