Old 01-07-2005, 11:32 AM
Crassshett Crassshett is offline
95 talon engine problems
My Talon just recently had another motor put in it. The problem is it keeps surging when brakes are on and the tak keeps jumpng on it, also when you try to give it gas it will backfire and the transmission acts slow on changing gears. I bought a new coil pak for it. If anyone has any ideas PLEASE HELP. Some friends put the motor in it for me.
Old 01-07-2005, 12:35 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: 95 talon engine problems
Check all your vacuum lines and shit. Does you CEL come on at all?
95 Talon TSI AWD
97 Eclipse GST
Old 01-07-2005, 01:06 PM
Yes the engine races up and down, and the engine lght will come on at that time too.
Old 01-07-2005, 10:08 PM
macder macder is offline
Send a message via MSN to macder
Not trying to be a jerk, but you need to tell us which motor you have (turbo or non-turbo). You will definetly get more feedback if people are more aware of what you have.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 01-07-2005, 11:54 PM
Sorry its not turbo and its a automatic, I don't know alot about cars but I believe its a 2.2 in it. I hope this helps out more.
Old 01-07-2005, 11:59 PM
Also the RPMS race up and down on it, and it backfires, seems to have a miss, I thought it was out of time but have been told these cars can't be times. The transmission seems sluggish on changing gears (not slippen though) or takes it time going into different driving gears
Old 01-08-2005, 01:10 AM
for one thing it's a Dual OverHead Cam 2.0L engine. second of all these cars can be timed and actually timing them correctly is VERY VERY VERY important, probably one of the most important things, if not the most important of all. are you having problems with gas mileage or anything like that??
95 Talon TSI AWD
97 Eclipse GST
Old 01-08-2005, 02:11 AM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
all cars can have timing adjusted
Old 01-08-2005, 02:36 AM
coolguycooz coolguycooz is offline
I think maybe your timing might have been messed up. But check the wires and plugs also make sure they are gapped right. And try to change your auto tranny fluid.
96 RS 5 spd.(Daily Driver and ex Ricer "I am ashamed of it")
98 GSX 5 spd. (Currently stock, spending all my mod money on body work.)
Old 01-08-2005, 10:24 AM
Re: Re: 95 talon engine problems
So is the timing done with the timing light? I haven't been able to drive because of the way it is running, I'm afraid it will break down. Timing though can do cause it to run like it is though right? I had a guy drive it and he thought it was the timing just by driving it.
Old 01-08-2005, 10:26 AM
When the motor was put in maybe a month ago all new fliuds were done too. I will check the spark plug gap though, the tranny fliud looks good and doesn't smell burnt either.
Old 01-10-2005, 07:25 AM
Think I got it fixed. Took it and had a dianostic which come up the Coil and it new, so I put new spark slugs and wires , and unplugged the coil and pludded it back in, and then had all codes erased and it runs like a new car. The guy said that even if coil was replaced and the codes were not erased it would still do the same thing, but it it would happen to do it again we think it maybe the wires going to the coil. Thanks for all you help
