Old 01-07-2005, 09:40 AM
pirates4ever pirates4ever is offline
Cleaning EGR on 95 4.3L 4x4
First off, let me say this forum has been a blessing. I have a 95 S-10, 4x4 with the 4.3L. Not sure of the engine code...I think Z, but I will have to check.
MY Check Engine light is on and I'm looking at fixing several of the codes it's reading. But I'm not sure this relates to that.
This past week, my idling and fuel consumption have been horrible. In the past this has happen due to carbon buildup in the EGR valve. So I've started the typical trouble shooting steps.
I added some injector cleaner in to my last tank of gas.
Yesterday, I cleaned out my Throttle Body.
My next step is to clean my EGR valve. In the past, this is something I've paid to have done but I'm getting tired of that and want to do it myself. I'm pretty sure I know where the valve is (right above the Throttle body) but I'd like to know if there is anything I should watch out for in cleaning it.
I intend to just remove it and clean with the same STP cleaner I used on the throttle body.
Is there anything else I should be cautious of? Thanks ahead of time for your help.
Old 01-07-2005, 09:43 AM
Mikado14 Mikado14 is offline
Re: Cleaning EGR on 95 4.3L 4x4
Search the forum, there's plenty on here for cleaning the EGR. Your LEGR should be BELOW the Throttle Body if you have a 4.3 Vortec. It will be round (like a juice can) with a connector on it. Sounds like you have this covered, Good Luck.
Old 01-07-2005, 10:05 AM
Yeah, I did that. I see it's a very common topic. However, I couldn't find specific pictures of what it looked like or any particular procedure on cleaning it.
I saw posts that mentioned everything from soaking it to just taking it off and cranking the engine to blow out the carbon.
I was under the impression it was above the Throttle Body. Now I'm not so sure I have the correct part identified. Basically I search Ebay for a picture of on and thought I had it narrowed down. Unfortunately, I don't have access to a Chiltons.
Any links to more specific information? Thanks!
Old 01-07-2005, 10:12 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Remove, clean and reinstall with a new EGR gasket.
No special technique is needed.
Don't drive it like this, it will foul your plugs.
GET OUT THERE AND FIX IT!
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-07-2005, 11:49 AM
OK, got the gasket I needed, and was able to successfully locate the EGR valve right where Mikado said it was. Thanks for the heads up.
One last thing; would the EGR valve cause starting issues? When I attmept the start the motor, it turns over just fine. But it takes me several attempts to get it to catch and when it does, it starts off with what appears to be a very low RPM then comes up to 650RPMS or so.
Thanks again all!
Old 01-07-2005, 11:57 AM
BlazerLT's Avatar
AF -Advisor
yip
Old 01-07-2005, 06:19 PM
OK guys, I just got done. First of, let me tell you I am NOT automotive technical savy. I'm a computer geek to put it in perspective.
Anyway, long story short, I found 2 bb size pellets of carbon stuck in the EGR valve. Used a boat load of STP Throttle Body cleaner and got all of the junk out. She's still starting a bit hard but once cranked she's running VERY smooth. Thanks for all the feed back BlazerLT and Mikado14. You just saved me $80.
For anyone who's going to try this I have a couple of words of advice.
1) Let you engine cool off! That's probably common sense to some of you, but then you have impatient people like me!
2) When you go to take the EGR Valve off, use an extension for your ratchet and come from the Fan through the serpentine belt to the bolt. It's MUCH easier. I didn't see that until it was time to put the valve back on.
3) Have some Throttle Body spray handy. The valve is going to be very dirty.
Anyway, I'm off to drive her a bit to blow the cob webs out. Thanks again guys!
Old 01-08-2005, 01:32 PM
BlazerLT's Avatar
AF -Advisor
Hope you used a fresh EGR gasket when you reinstalled it.
Old 01-08-2005, 07:58 PM
Oh yeah. Picked one up at the AutoZone. $4.95
Old 01-08-2005, 08:16 PM
BlazerLT's Avatar
AF -Advisor
Just checkin
Old 01-10-2005, 07:14 AM
Another update.
After putting about 150 miles on my truck since cleaning the EGR valve, the problem seems to have returned. Since I can now fix this in about 30 minutes, it's not as bad as it sounds but it is annoying to have it return so soon.
I read in one post what sounded like the guy cranked his truck while the valve was off to blow out the carbon. Is this a good idea?
Is there anything I can do to help prevent this from happening so quickly? The only precaution I've taken is to run a bottle of GumOut Injector Cleaner through my tank about once a month.
Lastly, I was wrong in saying my engine was Z, it's a W.
Thanks again!
Old 01-10-2005, 09:55 AM
Re: Re: Cleaning EGR on 95 4.3L 4x4
Originally Posted by pirates4ever
Another update.
Thanks again!
It sounds as if you have an unusual carbon buildup. You can do the cleanout you mentioned, just don't have anyone standing in front. You might be running on the rich side, you may want to check for washing inside of your plenum. Remove the cover and the IMTV and look inside with a light. If you see washing, you need parts (CPI and nut kit).
Also, when was the last time a complete tune-up was performed?
Old 01-10-2005, 09:57 AM
Roughly speaking, is there any thing that describes how to perform that task?
Also, about what would those parts run me?
Old 01-10-2005, 10:00 AM
Nutkit is about $56 from the dealer.
I purchased a CPI unit from our local jobber for $156.
You will also need a new plenum gasket.
How many miles since your last tune-up? How many overall miles?
Old 01-10-2005, 10:06 AM
Total miles are 169500
Last tuneup was at 125K miles.
I could use one, I'm sure. I've also got two P code errors I'm looking at fixing along with a tempermental 4x4 thing. All those appear to be very common based on my searches.
Truth be told, I'm just trying to get her a little better sounding so I can sell/trade her. So I'm not looking to spend much.
It's been a great truck but it's time for me to move on.
