ZQ8 Steering box ????
Okay... I have slop in the steering wheel and I want to get it out. I have changed out the idler arm and pitman arm... because it need it; then I changed out the ball joints...not so much because it need it now but with 115K miles on the car I decided to do it now rather than wait a nother year or so (and be safe); and I put heavy duty torsion bar spacers (I think they are polyurethane) on the front end. All of these repairs make my 97 Blazer 4x4 ride much better, but I STILL HAVE SLOP IN THE STEERING!
I don't want to live with this problem. Can anyone suggest a solution to this problem and/or confirm that replacing my OEM steering box with a ZQ8 steering box will do the trick? ... How much are we talking about, and where can you buy one? (PS I did replace the donut/rag and that helped a little, but not nearly enough.) |
Re: ZQ8 Steering box ????
Can you tightenup the steering box?
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: Re: ZQ8 Steering box ????
try it, if it helped before a bit.
why the zq8, why not a cheaper standard steering box?
Good question. I don't need a tighter turning radius or more "action." I just want to get the slop out of the wheel when I'm heading down the highway. Will a standard steering box (NOT OEM I PRESUME) do that? If so, can I find one with the side adjustments for wear? Any particular brand? (In this case, cheaper sounds just as good as more expensive to me.) |
any brand will do, but you should check your tie rods for play.
They are more directly related to sloppy steering than ball joints.
