Old 01-07-2005, 01:43 AM
texwill texwill is offline
stuck in 4 wheel drive???
Yesterday I took my "NEW" 94 S-Blazer fourwheeling, it is basically stock except for 31" AT's. Now the truck performed great as a matter of fact it kept up with my buddies 88 Rover with a susp lift, 33's, and a rear diff lock. Anyways, when we were done I took it out of 4 low and went to 4 high to get off the trail, got on the street, took it out of four wheel drove a bit the did a powerbrake to smoke the tires, well after the smoke let out we started to cruise. We then started to hear a tire squealing and the steering wheel was pulling hard to the right. So I pulled off to a gas station. While making the left turn both tires started chirping like it was still in four wheel drive. We stopped inspected the vehicle went back through the 4 wheel gears back to 2wd. Then my friend said he had heard some trucks had to be driven in reverse to get the 4wheel to disengage, I have never heard this but it seemed to work cause we drove back home with no problems. later that day I engaged the 4wheel again and disengaged it while driving, 4high, it was doing the chirping again and pulling hard to the right, then a loud CLUNK and was fine. Is something broken? Not working right? Or is it just like this all the time, or does driving backwards really work? Thanks!
Old 01-07-2005, 09:52 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: stuck in 4 wheel drive???
Is this an electronic 4x4 ?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-07-2005, 09:59 AM
Mikado14 Mikado14 is offline
Sounds like the vacuum switch on the transfer case is not releasing the front axle completely. Cheap fix, change it. However, you may also want to check the actuator motor (under the battery) and the cable to the front axle.
Old 01-07-2005, 08:17 PM
crazys182003's Avatar
crazys182003 crazys182003 is offline
I would check your 4x4 fluid. Were you in water that coulda gotten in? Mine has been "stuck" in 4 high before and I drove it abckwards only to find out it actually did realease. Up until this eyar I neevr had to drive in backwards to get it to realease. Looekd at my fluid was choclate milk in conisitancy and color. That told me I need to drain and change it. Water got in it and caused problems. Checking the fluids is a very easy and quick task to start with in my thoughts. But yes also check for vacum if your fluid is fine.
Old 01-08-2005, 01:27 PM
BlazerLT's Avatar
AF -Advisor
Very true, your differentials and transfer cases should all be serviced every 60,000 miles or so with new fluids.
Old 01-10-2005, 01:40 AM
I checked the diff fluids this weekend and all is well, it was full, but I drained it anyways and put in new fluids, it has new half shafts, (still has paper stickers) where can I find the vaccum part for the transfer case and what is the exact name so I can change it anyways?
Old 01-10-2005, 01:47 AM
Turbocpe Turbocpe is offline
Napa has them and calls them vacuum lock out hub switches.
Old 01-10-2005, 01:48 AM
Great thanks for the quick reply, I am stationed in Germany and it usually takes awhile!
Old 01-21-2005, 05:13 AM
OK the problem is getting worse, anytime the tires lose traction, the four wheel drive is engaging!! I have to stop, take it out of 2 wheel, switch through the gears, then put it back in two wheel and drive backwards a few feet for the 4 wheel to disengage. Would buying the vaccum switch in the pic above fix this problem?
Old 01-21-2005, 05:15 AM
also it is manual not electronic four wheel
Old 01-21-2005, 09:19 AM
anybody????
Old 01-21-2005, 10:14 AM
BlazerLT's Avatar
AF -Advisor
This is weird, never heard of somthing going INTO 4x4, rather mostly going out of it.
Old 01-21-2005, 05:55 PM
Re: Re: stuck in 4 wheel drive???
You haven't mentioned if you have checked anything yet. Have you checked the actuator under the battery tray? Have you checked the vacuum switch on the transfer case? Real easy to see if is bad, here is a photo of a good one and a bad one.
Old 01-21-2005, 08:19 PM
molehole's Avatar
molehole molehole is offline
Send a message via AIM to molehole
Your hubs could also be getting worn out. How many miles are on your Blazer? Sometimes worn out hubs can engage themselves(at least partially). Good Luck
Old 01-22-2005, 09:04 AM
It's a '94, there are no lock out hubs that I have ever seen. Engagement of the front axle in done inside the front differential.
