Old 01-07-2005, 12:29 AM
3000GTRip 3000GTRip is offline
I Lost Again!!!!!!!!!!
lolz
Old 01-07-2005, 01:02 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
your 3000gt also weighs alot more than his grand am does. and yours is a little older so it is bound not to be running at tip top condition.
as for finding a manual transmission, check out your local wrecking yards. if they dont have one for you, im sure they might be able to order one for you, from another yard. also, contact a couple front clip importer companies...they can usually get just transmissions for you too. i dont know if they made a only FWD GTO in japan but if they did then you could also get one shipped from there.
but along with that manual trans. your gonna needs quite a few more parts. an auto to manual swap isnt exactly like changing your air filter.
parts to do a auto - manual conversion includes:
clutch slave cylinder
clutch master cylinder
clutch pedal assembly
brake pedal
shifter assembly
manual transmission
clutch & flywheel (if your trans doesnt include those things)
hosing to plumb the cylinders
clutch lines
not to mention some other wiring issues your gonna aquire...and i probably forgot a couple things. if you already knew this stuff, just ignore it...
ZedEx Crew Member #4
Old 01-07-2005, 01:07 AM
Re: I Lost Again!!!!!!!!!!
yea i know i need all of that not too too bad.. Its just i cannot not find a tranmission at all
Old 01-07-2005, 01:10 AM
Z Cars Fanatic
ok go here...this is a wrecking yard database type thing. just fill out the form, and then you will have wrecking yards from all over the country email you, offering the parts you need along with the price. i have used it a couple times and i get 5 or 6 emails within 24 hours.
http://www.uneedapart.com/
Old 01-07-2005, 02:07 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
keep checking on ebay, they pop up every couple of weeks...i waited for a few weeks for mine and was well worth the wait.
You shouldn't have lost to a Grand Am GT...unless you were just going short distances.
Check the FAQ, tell's you everything you need to know about the swap.
Old 01-07-2005, 02:39 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
www.car-part.com
that site is a database for all salvage yard places. i found my suspensions parts from there. had a whole list of places, but called around, found one near me, that had good prices, went with it. you'll get soo many hits if you search for a 3000gt tranny.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 01-07-2005, 08:43 AM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
Just cuse your car came with 222 hp stock does not mean it is making 222 hp after 11 years. When I bought my car and dynoed it it was at 172 hp, after a head job and tune up and new clutch it made 208, after mods its at 225 so its not always 222, thats just the stock figures we use for comparison to other cars stock figures.
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 01-07-2005, 09:09 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Grand AM GT's are low 16 second cars. I have said it once and I'll say it again for the most part ATX 3/s's are mid to high 16 second second cars. I know some others like to disagree, but what are you gonna do?
If you would have raced to a top speed you probably would have taken him though.
Old 01-07-2005, 12:22 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Woahhh auto is that much slower? I thougt they were liek.2sec slower not allmost 2 seconds!
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 01-07-2005, 12:33 PM
Yeah I've heard a couple of tenths slower not 2 seconds but I'm not gonna argue cause I'm not sure.
Old 01-07-2005, 02:02 PM
sLADe781 sLADe781 is offline
Hey Musashi, wasn't it expensive to dyno it so many times?
Old 01-07-2005, 02:19 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Also, its 222 at the flywheel. When you dyno you get the power at the wheels, 172 FWHP is about right.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 01-07-2005, 02:31 PM
Thourun's Avatar
What % range are the losses from the different drive types? I wana know how much 500 flyhp is and how much 500 front wheel hp is.
1995 3000GT VR-4
Old 01-07-2005, 03:14 PM
Z Cars Fanatic
i dont know about FWD, but RWD you lose about 20% from the flywheel to the wheels and AWD you lose about 25% in most cars. my guess would be that FWD also loses about 20%...but that would be a guess.
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
those grand am gt's are no slouches, there decently quick. bout 15.0 sec cars, with your auto its probably about a 15.5 second car
