Old 01-06-2005, 10:59 PM
dyaballikl dyaballikl is offline
How to pull off window crank to remove door panel?
Can anyone tell me how to pull the window crank off the door of my Mercury Tracer so I can remove the door panel? Thanks a ton!!!
Matt
Old 01-07-2005, 12:36 PM
mlw35405 mlw35405 is offline
Re: How to pull off window crank to remove door panel?
Slip a rag between the handle and the door and work it back and forth-this will push the metal clip that holds it in out and the handle will slide off.
Old 01-07-2005, 11:22 PM
Huh, ok, I'll try that. Thanks
Old 01-08-2005, 04:58 PM
94GTscort 94GTscort is offline
if its a manual window, you can buy a tool to remove a clip off of the window crank, so you can take the panel off.
Old 01-08-2005, 05:42 PM
I think I'll stick with the rag, sounds cheaper
