Horn problem
This evening we left a restaurant to find our 99 SL1 with the horn blaring. tried to push the horn buttons with no response except for a little sound variation in the horn. started the car up to find out the horn wouldn't shut off. after driving the car a bit, the horn and the sound died off. horn doesn't work anymore...any ideas what happened and how to fix it?
Re: Horn problem
eww, i had that problem. i went and bought a new horn. cut n spiced the wires onto it. but idk why it did it... i'm sure the other smart guy on here knows
1995 Gold Saturn SL2 -- RIP May 05 1991 Blue Subaru Legacy Wagon -- RIP Aug 05 1995 White Mazda 626 DX -- RIP Feb 07 1991 Black Volkswagen Jetta Carat -- Current |
Re: Horn problem
possibley the horn shorted out(most likey the relay), after being on so long, the fuse blew. if your horn has two wires the relay is in the fuse box by trhe battery, if it has three wires, the relay is internal. the three wire style must be tested with a multimeter. for the two wire style - first check the fuse, if it is blown, replace it, but be prepared to pull it again if the horn blows. if it does blow, pull the relay, if the horn stops, replace the relay with another relay for testing, if the horn stays off, test the horn buttions on the wheel, if they now work normally, the relay is bad. if anything other then the above happens, farther testing with a multimeter is needed.
Re: Horn problem
see i told you the other smart guy would know
I screwed my horn up royally this summer trying to fix a similar problem. Took out a three wire horn, tried jimming riggin' a two wire horn to work, worked for a while but then I had the continual blaring problem until it died out. How do I fix my horn now????? And what was that third wire for anyways? Thanks.
Re: Horn problem
its just a relay wire
dead horn
i cant even find where the horn is-- heres the story; girlfriend took her car to the shop because it wouldn't start- she got the car back and horn didnt work, where is the horn located and how would you know if the relay is bad- when the fuse is good?
Re: Horn problem
its hidden up somewhere inside the bumper. you can test the relay by swaping it with another known good relay (like A/C, foglamps, or fuel pump)
Re: Horn problem
I have this same problem with my 97 SL2
I have a 3 wire horn. So I guess I just need to change the horn out with a new one? I have the fuse out because I took it out before it blew because this has happend before and I was hornless for a few months, then one day it just worked again. then went on a blowing rampage. Now I'm up for inspection and it doesn't work. |
Re: Re: Horn problem
don't assume, test it. buy a $5 test light. of the three wires, one should have ground, one should have power always, and the last should have power only with the horn button pressed.
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles EPA 608 Universal Certification EPA 609 Certification |
