Old 01-06-2005, 09:56 PM
drizzt615 drizzt615 is offline
Problem with Reverse
I am getting no power when I put my car in Reverse. I just did a fluid and filter change, cleaned the magnet and pan and replaced the gasket with still no change. When I put the car in Rev. IF it rev it up to about 6500/7000 RPMs MAYBE it might go backwards 3 inches. Can anyone help clue me in as to what the problem might be and or how to fix it. Thanks in advance.
Old 01-06-2005, 10:09 PM
lionelkirk2004 lionelkirk2004 is offline
Send a message via Yahoo to lionelkirk2004
Re: Problem with Reverse
I think that it something with transmission.
Old 01-07-2005, 12:47 PM
GTP Dad GTP Dad is offline
Pontiac Guy
I agree with lionelkirk2004, you have a transmission problem that is going to take a tranny shop to repair. It could be a bad reverse clutch or solenoid but a transmission repairman will be able to determine that for sure.
Old 01-07-2005, 04:14 PM
Lightbulb
Well not to be rude but, it doesn't take PHD in Astrophysics to figure out thats its a tranny problem. I was hoping for some advise other than "take it to a mechanic". I guess it was my own fault for not being specific enough. I figured it was assumed that it was a transmission problem when I wrote that I changed the fluid, filter and seal.Does anyone one else have any advise?
Old 01-07-2005, 04:20 PM
jon@af's Avatar
jon@af jon@af is offline
The Media Guy
Send a message via AIM to jon@af
Well, my dad can do transmissions in about 2 1/2 hours, and is a certified master technician. I'll ask him when he gets home and see what he thinks and get back to this thread .
AF User Guidelines <----Click and read if you don't know these.
"Dream as if you'll live forever. Live as if you'll die today."
A Blog By Swigz
Cotidie damnatur qui semper timet; Aquila non captat muscas.
Old 01-07-2005, 06:26 PM
jon@af's Avatar
The Media Guy
Does it have all the other gears? Also, what engine do you have and is it the 4 speed automatic?
A Blog By Swigz
Old 01-07-2005, 08:03 PM
Yes it has all other gears. Just not Reverse. Its a '93 3.3L V6 3 spd Automatic. (it has Park, Rev, Neut, Drive, L1 and L2)
Old 01-07-2005, 09:07 PM
jon@af's Avatar
The Media Guy
You may have either a broken reverse band or a bad reverse servo. Either way, you're most likely going to have to take it in and have the transmission torn down to get it fixed.
A Blog By Swigz
Old 03-31-2005, 09:57 AM
DAMIANBAYLISS DAMIANBAYLISS is offline
I just had the problem fixed, I was doing this for a year or so, it got to the point that i had to put in in 2nd and then it would engage, but i didn't want to spend the cash to fix an internal problem. The problem is with the dip stick, I just brought my car into the shop today at 8:00am and i was fixed at 8:05am all it is, the mechanic told me was out of the factory the dip sitck was too long thus when you had it serviced(probably at a regular shop not a tranny shop) they fill it up to the factory spec.(which are wrong). He told me that you should add a liter to a liter and a half, he did it for me for free and now it works like a charm. Let me know if it works.
