Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 01-06-2005, 09:39 PM
chadburris chadburris is offline
Question front end noise
does anyone experience a squeek from the front end when the road gets slightly bumpy? sounds like its coming from the front left wheel.
Old 01-07-2005, 06:47 PM
chubbybubba1 chubbybubba1 is offline
Re: front end noise
Mine squeeks on colder mornings in right hand turns into a drive or dip. X 01'
Old 01-08-2005, 07:22 AM
any idea what causes it? mine does it regular, cold or not.
Old 01-10-2005, 09:50 AM
Re: front end noise
I'm going to apply a little grease to the front sway bar bushings at my next service.
Old 01-10-2005, 11:21 AM
Schludwiller's Avatar
Schludwiller Schludwiller is offline
XTerra Guy
Re: Re: front end noise
The front sway-bar mount bushings in the center are toast after 3-5k miles. Lube helps, but the rubber will be worn in the center. There is a Energy Suspension part that can be "made" to fit, but nothing is manufactured directly.
Energy Suspension front sway center bushing: 9.5162 (don't use brackets, reuse stock)
Xterra4x4.com and the Xterra Offroad Webring
Old 01-10-2005, 11:26 AM
Re: front end noise
Thanks for the input. I used the Energy greasable rears already. I already should of addressed the fronts.
