Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-06-2005, 09:29 PM
SlickSL2 SlickSL2 is offline
Send a message via AIM to SlickSL2
shifter - maybe clutch?
I own a 94 sl2 DOHC 5 spd. Lately i have noticed that when i try to put it into gear that it sticks....i have to cram the shifter into every gear....even reverse. it only happens when the car is on. I have checked for leaks in the clutch master slave cylinder and there are none. What else could this be? HELP
Old 01-06-2005, 11:36 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: shifter - maybe clutch?
does double clutching help?
possibly clutch, cables, syncros(unlikey), or fluid too thick(it should be ATF, not oil)
Old 01-06-2005, 11:42 PM
carguy83 carguy83 is offline
Send a message via AIM to carguy83
try pushing down on the clutch all the way too
1995 Gold Saturn SL2 -- RIP May 05
1991 Blue Subaru Legacy Wagon -- RIP Aug 05
1995 White Mazda 626 DX -- RIP Feb 07
1991 Black Volkswagen Jetta Carat -- Current
Old 01-07-2005, 06:06 PM
ok so i woke up this morning only to find that the clutch is feather light and i cannot put the car into gear. I talked to an auto shop by my work and he said that to replace the clutch he would have to order a certain 'hydrolic' part from the saturn dealership. I am going to purchase a SPEC stage 2 clutch anyways but i want to be 100% positive that it is the clutch.
Old 01-08-2005, 10:01 AM
it really sounds like a clutch problem to me
Old 01-08-2005, 01:29 PM
now it grinds when i try to put it into gear.
Old 01-08-2005, 01:54 PM
Roadkill Roadkill is offline
Send a message via Yahoo to Roadkill
I had a similar problem with the clutch on my 95 SL2. The problem was intermittent, but when it acted up you could not get it into any gear, period. I checked to make sure that the clutch pedal was being pushed down all the way, and had the proper amount of fluid. Still, could not get it into any gear. I pulled the cover on the shifter and checked to see if any of the cables were binding. Was fine, but still had issues. When at my wits end, the problem went away as suddenly as it had appeared. It lasted off and on for about 2-3 weeks. That was about 4 months ago. I believe it was a slave cylinder problem. Could have possibly been trash or something in there. Still don't know what happened to this day. Certainly stumped the Saturn Dealer! If it ever comes back I'll tear apart the whole clutch system and rebuild it with all new pieces.
Old 01-08-2005, 03:07 PM
ok well my friend had this problem and basically he taught his girlfriend how to drive and she screwed his tranny all to pieces. it was griding and it wouldnt go into gears easily. he had the tranny replaced and it fixed the problem for a little while. then it started doing it again and so he replaced the clutch and the problem never came back... i'd start with clutch and then go tranny
Old 01-08-2005, 03:50 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Re: Re: shifter - maybe clutch?
Why stage 2? A stage 1 will work just as well unless you have or plan to have a lot of extra horses under the hood.
Old 01-08-2005, 04:28 PM
plan #1 = turbo
im already in the process of making my own kit. An upgrade to a stage 2 was already on my list but i didnt want to replace just the clutch without knowing that something else i wrong.
Old 01-09-2005, 05:45 PM
really sounds like the clutch, check fluid
Old 01-09-2005, 05:58 PM
i checked the fluid on the dip stick and there was plenty. It didnt seem thick at all. I'm assuming its the clutch and not the slave cylinder. I am going to take it to a shop this week and find out for sure what it is.
Old 01-10-2005, 12:52 PM
streetracr32's Avatar
streetracr32 streetracr32 is offline
it probably is the clutch. but first, do you have a hydraulic clutch in ur model. i have one in mine; it could be the source of ur problems, from what it sounds like.
Old 01-10-2005, 08:42 PM
i'm pretty sure its a hydrolic clutch. sierrap615 would be able to tell me. how would it be the source of my problem. Im clueless when it comes to clutch and transmission work. im only 17 years old so i'll learn. My boss told me that if i buy the clutch and bring it in that he'll help me install it. I am going to get the stage 2 SPEC kit from SPS. It comes with the disk, pressure plate, alignment tool, and a new throw-out bearing. Is there anything else that i should replace while my car is in pieces?
Old 01-10-2005, 11:45 PM
all S-series are hydralic clutches, and i think all other saturn models are too. the hydralics replace the linkage or cables for the clutch as seen on older cars. when you press the pedal down, it transmit the force to the move the pressure plate out. the clutch is sandwiched between the pressure plate and flywheel, clutch moves at the same speed as the trans, the pressure plate and flywheel moves at engine speed. the pressure plate is under extreme spring pressure, so be careful with it. the spring pressure clamps everything together so the clutch doesn't slip. when you press the clutch pedal down, you are overcoming that spring pressure so the pressure plate, clutch, and flywheel can seperate and the engine and trans move freely from each other. so if the hydrolics(which are self adjusting) crap out the clutch can ether clamp to much or not enough. remember the fork that moves the pressure plate only moves back and forth, the pressure plate is rotating. thats where the throw-out bearing comes in, as with most bearings, it allows a moving part to contact a non-moving part. rotating, non-rotating, engine on, engine off, see where i'm going? that bearing is fighting the spring pressure from before. holding the clutch in for a long time will wear out the bearing(put it in netral at red lights, train crossings, and such)
you will need you replace the hydralics too.(standard procedure)
inspect flywheel, resurface if nessacry(or if you want to upgrade to a lightwieght flywheel), check the engine rear seal and transmission front seal for leaking, inspect the ring gear on the flywheel, careful with the axle seals. inspect/lube shifter cables(white lithuim grease),inspect cable retainer clips. there are a few how-tos on saturnfans.com
