Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-06-2005, 09:23 PM
newmangrape newmangrape is offline
Send a message via Yahoo to newmangrape
service 4wd switch
I have a 94 gc with the 4.0 , quadratrac , my message center periodically flashes "service 4wd switch", what is the 4wd switch? and where is it located.
Old 05-16-2005, 10:08 AM
rleemann rleemann is offline
Service 4WD Switch
I also own a 96 Jeep GC 5.2 LMT 4x4 with the very same problem coming up on my "VIC" (vehicle information center) as you have on yours, that is the message "Service 4WD Switch." Kind of a pain in the ass wouldn't you say. The switch it wants you to service is simply the replacement of one of a possible two different part numbers: 56006755 $33.45 or 83503525 $37.85 based on the type of transverse case you have. The part just screws into the TF case when you pull out the old one and switch the wiring just below the driver's seat by back drive shaft. I changed mine out the 755 one only to have the problem come up again. I think it is something to do with the chip or computer and can't afford to replace that so I am just going to disconnect the warning to the buzzer under the bottom of the steering column, I know it defeats other warning but I am tired of hearing the one about the 4WD Switch.
Old 05-16-2005, 01:18 PM
croozer croozer is offline
Just disconnect the wire from the switch on the transfer case. Done! It only tells you weather you are in lo or hi. Serves no other purpose. No harm to anything. Mines disconected for a year now...No problems.
