Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-06-2005, 07:51 PM
Motegra98 Motegra98 is offline
Send a message via AIM to Motegra98
Question Exhaust
I recently did an ls/vtec done on my car and was wondering if i could put a gsr exhaust system on my car. The only conflict with this is that im not sure if the 02's will line up or be in the correct position. Also which is the largest and most performance wise size should i put.
Old 01-09-2005, 12:39 AM
DaBatThrower DaBatThrower is offline
Re: Exhaust
y would you want to do this?
Old 01-09-2005, 12:45 AM
gsr916 gsr916 is offline
Banned
Send a message via AIM to gsr916
Re: Exhaust
yea why would u want to put a stock gsr exhaust on ur car?
Old 01-09-2005, 12:17 PM
Re: Exhaust
in my humble opinion you should probably go with aftermarket exhasut designed for your car. By the time you get done with the fabrication that this is probably going to take it may end up costing similar numbers any way. You could also make custom exhaust by just buying the piping , getting a high flow cat and a good aftermarket muffler. Take it to a muffler shop and they'll hook you right up(make sure you get mandrelbends though).
But if you have your heart set on gsr exhaust then go for it.
-DaBat
Old 01-09-2005, 12:41 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
I was under the impression that a gs-r exhaust was the same as ls/rs/gs. If you want a better flowing OEM exhaust get a type R exhaust. It will be slightly more free flowing and will have a nicer sound to it. And I believe it will bolt right up.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 01-09-2005, 01:09 PM
97integrals's Avatar
97integrals 97integrals is offline
I believe what he is asking is that he has done an ls/vtec conversion and he is trying to buy an aftermarket exhaust but he doesn't know if he needs to buy an exhaust that fits a gsr or an ls.
Old 01-09-2005, 03:10 PM
what im saying is, i purchased a dc header 4-2-1 a pc. and was shipped the gsr header by mistake. i was wondering if i could just go gsr exhaust all the way back. the only problem that i have come across is the hole for the o2 sensor is not in the gsr header. i have been told that it will line up if i get a aftermarket gsr cat and exhaust. i just need to know if there is a way i can put the o2s in.
