Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-06-2005, 07:25 PM
TeamNDM1 TeamNDM1 is offline
Send a message via AIM to TeamNDM1 Send a message via MSN to TeamNDM1 Send a message via Yahoo to TeamNDM1
Angry air ride suspension problem
Ok heres my prob. I've recently aquired a very customized 00 dodge neon, im strongly regreting said aquirement. Amoung the list of mods is the bags, well ill just give you the story. First i just wanted to install some subs, simple enough since its already wired for an amp, so i went to work, well 15 mins later im done with no result, the subs arent hitting and the amp isnt on, i checked the fuse on the power wire and it seems fine. so fed up i unhooked everything and taped the wires up and planned on calling it a day, then i notice my tail lights were on and the key wasnt in the car, i tried to start the car and it wouldnt start, i found a switch to cut the tail lights off so thats fine. i replaced the starter relay and the all relays fuse, it crunk just fine yesterday, but today it sounds like the starters bad and it wont crank at all, more my question is why my bags wont raise, the compresser turns on just fine, but when i hit the switches the valves dont click or do anything at all. Ive asked a few ppl for help and they dont seem to be able to, i dont know if the power for the valves is the same as the compressor or what, but all the same im at a complete loss for ideas here any thing anyone can suggest would be helpful. better yet if you live near me please come help.
Old 01-07-2005, 01:34 AM
integrawhat integrawhat is offline
Send a message via AIM to integrawhat
Re: air ride suspension problem
well where do ya live? you need to get a volt meter at auto zone for like $12 (you'll use it forever) and test all the power lines to the bag valves but if none of them work at all then the prob should be in the switch box but the voltmeter should be the only tool you need to fix this once you locate the open circuit just close it but get a friend to help and have him hit the switches while you test the individual wires (and did everything work when you bought it and do you have acces to the guy you got it from he might be able to help you easier or get a hold of the shop that did the instal cuz most people dont bag there cars themselves) but i would definatly say if none of the valves work the probs in the controller the power for the compressor and valves shouldnt be the same and each valve should should have its own fused power line but once again get a volt meter and let me know what you find out.
A.K.A. GOT WIDE
darton 84mm MID's ls stroke 2.0l GS-R
pnp head with full skunk2 pro series valve train
and pro1 cams
custom divided top mount w/garrett gt4094r
not stoping till i hit 750hp to the wheels
this aint your mom's car so DONT F***ING TOUCH IT
Old 01-07-2005, 05:46 PM
i live in upper South Carolina, Lancaster to be exact, i doubt anyone stays near me, but i get payed next week so ill pick one of those up, thanks a lot, and if you know anyone who wants a neon im selling for 4k obo.
