Old 01-06-2005, 07:13 PM
tardster tardster is offline
? for a buddy
Hey guys I know this is not about a camro but my buddy needs some help. He posted a question in the mustang forums but they just ignored him. Anyhoo, he has a 67 mustang and noticed the back or rear part of the frame has some pretty good rust on it and since its a unibody he cant find any parts to replace it. Anyway please no flaming, he just needs abit of help and any and all is appreciated. thanks guys
Old 01-06-2005, 07:19 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: ? for a buddy
I'd say cut the rusted part out and weld in new material.
Old 01-06-2005, 07:24 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: ? for a buddy
grinder, and por15 if its nott toooooo bad, and like geno said, extra metal, and a welder if it is.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 01-06-2005, 07:28 PM
See I was kinda wondering if there was anything that would go right over the old and then could be welded on once it was cleaned up or if could it just be boxed over?
Old 01-06-2005, 07:30 PM
Rod&Custom's Avatar
Rod&Custom Rod&Custom is offline
Send a message via Yahoo to Rod&Custom
Just grind it down and weld in some heavy-gauge metal right over the bad spot. Just make sure to weld it good....
Old 01-06-2005, 07:44 PM
Genopsyde's Avatar
The President
Re: ? for a buddy
is there an echo in here?
Old 01-06-2005, 07:45 PM
89IROC&RS's Avatar
Re: ? for a buddy
nope, you have to get all that rust off, there is a reason they call it cancer, it will eat up the original frame, right out from under the new material, and eat that up too. grind off al the rust, weld on the support, and then prime or coat it to keep it from rusting again.
Old 01-06-2005, 07:49 PM
Genopsyde's Avatar
The President
Re: ? for a buddy
no, you'll have to get all the corrosion off, that's why they call it cancer, it will eat up the frame, right out from under the new metal, and consume that too. grind off all the corrosionand weld on new support, then paint it to prevent further corrosion.
Old 01-06-2005, 08:00 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: ? for a buddy
I don't think so, you will have to remove the infected area. Its a infection like cancer. It will eat away at your vehicle under-body and before you know it, it will be consuming the new uninfected area.. Use a grinder to remove all the infection and weld in the new material. Make sure you prime the area to prevent new infection.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 01-08-2005, 12:04 AM
Genopsyde's Avatar
The President
Re: ? for a buddy
awesome suggestion formula.
Old 01-08-2005, 12:12 AM
92rs25th's Avatar
92rs25th 92rs25th is offline
Send a message via MSN to 92rs25th
Re: ? for a buddy
Actually rust is has to have oxygen to continue to spread , if the rusted areas were 100 % covered with some wrap metal and then weld sealed , the runst under that couldn't spread however , it would leeave that as a weak spot. You would only be making the new metal welded on there the strong point not the rusted area being reinforced.
I love rice so much , I eat it daily. Yum yum Civic.
1992 RS Camaro 383.
2004 Mazda 6.
2003 Subaru Legacy GT Limited.
1984 Nissan 300 ZX
1993 Mazda MX-3 ( Newest addition to my collection. )
http://photobucket.com/albums/y187/ohjiro
Old 01-08-2005, 12:14 AM
92rs25th's Avatar
Re: ? for a buddy
Oh , I don't remember what it's called but there is a chemical you can get and put on there , it eats the rust off in less than 4 hours exposing clean new metal again. For some reason it only attacks rusted areas and hurts no other materials..spooky but it works good. Should have it home depot / lowes / eagle ..etc. Much easier than grinding or sanding or buffing
1992 RS Camaro 383.
2004 Mazda 6.
1984 Nissan 300 ZX
Old 01-08-2005, 12:36 AM
Genopsyde's Avatar
The President
Re: ? for a buddy
I can't recall the name, but there's a substance that you can purchase that dissolves the corrosion in under 5hrs revealing clean steel again. I don't know how it only attacks the corrosion and nothing else, frightening but works. It should be in stock at your local home improvement retail stores. It's not nearly as difficult as using abrasive materials on it.
Old 01-08-2005, 12:43 AM
FormulaLT1's Avatar
Fight the powwa!!!
Re: ? for a buddy
I don't seem to remember the name although there is this stuff that you can purchase that removes rust it says it requires about 4 hours but usually takes about 3. Even though I have a hard time grasping how it works it takes away the infected portion while revealing a clean area to work with, It should be available at any place you would be able to find home refurbushing materials plus it requires much less work than using a grinder would.
Old 01-08-2005, 01:01 AM
92rs25th's Avatar
Re: ? for a buddy
Haha , very mature. psh.
1992 RS Camaro 383.
2004 Mazda 6.
1984 Nissan 300 ZX
