jeep service manual
does anyone have a factory jeep service manial for a 1990 lerado?I need to know where the tanwith black stripe wire goes from back of alt.what pin on the back of dash is it?this wire is suppose to be for volt gauge.thanks wayne
Been there checked it... No luck..
Re: jeep service manual
The tan wire goes to pin 3 on the 18 pin connector of the instrument cluster. It is for the alternator lite.
The wire for the volt gauge is at pin 6 (white with black tracer) on the same connector. It gets power from the gauges fuse as well. Does your volt meter work??? Thats the best info I have. JD |
Re: Re: jeep service manual
If there are numbers you will need a magnifying glass if your like me!!!
should be third one from the end and next to a blue wire (if I'm right). If I'm not, look for the same color/tracer wire in the connector. This is making less sense now that you say you have no lite. I hope you can find something here with what I've given you. I won't be able to check anything else till morning. JD |
glassman,
this might help in the future, i'm guessing the 1988 is close to yours. http://www.lunghd.com/Downloads_and_Links/Downloads.htm |
i use winrar. do you have any computer guru friends? cause i don't know computers well enough to explain it to you. can you right click the file and "unzip" it. it should be pdf. file after you unzip it.
Glassman556:
Go to www.cnet.com and go to downloads. In the search box type Winrar or WinZip. Download it and after it's download go to that filename and doulbe click on the filename that has .exe on the end of the name. It should install that program. So now go to the downloaded file and it should unzip and you should be able to read the .pdf files. If you don't have Adobe Acrobat Reader go to www.adobe.com and go to downloads and download the reader. |
