Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 01-06-2005, 06:30 PM
Retard324 Retard324 is offline
Send a message via AIM to Retard324
clank sound in reverse
whenever i'm goin in reverse theres a clank sound comin from the front left, i was told it might be bushings in the sway bar stiffening from the cold. could that be it?
'93 Nissan 240sx
'90 Nissan 240sx - KAE-T? might go NA instead
Old 01-08-2005, 02:28 AM
car_boy_16 car_boy_16 is offline
Re: clank sound in reverse
Check your engine and tranny mounts - dont be surprised if one of them is bad....I've never heard of sway bar bushings creating a clunking noise when putting it in reverse, I dont even know how it could cause such a thing...
Without even looking at any tranny mounts or engine mounts, you can figure out if that's the problem by simply having someone put the car in reverse while youre looking at the engine for any movement - if there is movement when it's put in reverse, then you know it's a mount...
Old 01-11-2005, 08:24 AM
PoorLuder PoorLuder is offline
Does this happen when you first start the car in the morning (backing up out of the driveway)? If so, your calipers are just cold and need time to warm up. My car has been doing that ever since the temperatures have dropped.
Old 01-11-2005, 12:41 PM
no, brakes are all warmed up. first started happening when i stopped in a parking lot for about 10min. put it in reverse, right before it started movin there was a clank sound comin from the left side
'93 Nissan 240sx
Old 01-11-2005, 02:29 PM
dalude_24 dalude_24 is offline
do you think its worth changin my non vtec prelude into a vtec
Old 01-11-2005, 02:31 PM
do you think i should do that car boy
Old 01-11-2005, 04:24 PM
Re: Re: clank sound in reverse
When did we get all these little kids running rampant through the forum?
If not the brakes...then I am not really sure. My knowledge is pretty limited. Sorry. Did you try what carboy suggested?
Old 01-12-2005, 01:55 AM
hontoy's Avatar
hontoy hontoy is offline
Banned
I GUESS ITS TIME TO GET A NEWER CAR..
Old 01-12-2005, 02:10 AM
Just try it, retard324...It will only take a couple minutes.
Old 01-12-2005, 08:00 AM
i procrastinate a lot, i'll get around to it an let you know
'93 Nissan 240sx
