Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-06-2005, 03:10 PM
Jpv Jpv is offline
engine swap question
I know this is not a Mustang question but I don't see a Tempo forum so..
I have a 94 Tempo with a 2.3 and the motor is shot. I found a 92 Tempo with a 2.3 with low miles that is wrecked. I can get the car for very cheap but am wondering if the 2.3 is interchangable from 92 to 94?
Thanks
Old 01-07-2005, 11:53 PM
macx macx is offline
Re: engine swap question
As long as it's the same basic motor I would think so. You may have to change something external, like maybe exhaust or intake manifold, accessory brackets, etc, but I would suspect the engine should be essentially the same. You could also check engine specs in a big Chilton type manual usually to be found in the local library.
