Old 01-06-2005, 02:59 PM
1995GTP 1995GTP is offline
Car won't idle when cold?
When I start the car it starts normally(don't have to crank very long) but right after it starts the RPM goes to around 2500 and then falls to below 500. Sometimes it will die, other times it will race back up to around 2500 and do the same thing over again. I had the codes pulled and the only thing that showed up was code 131 - O2 sensor voltage low. everything else checked out ok. Any idea what could be causing this?
1995 GTP 3.4L DOHC
Old 01-07-2005, 11:05 PM
dralldaylong dralldaylong is offline
me2
i have a 99 gtp and am having the exact same problem.. would like to know what might be the problem so i can get my car fixed.
Old 01-20-2005, 07:53 AM
PYMATUNING PYMATUNING is offline
Sounds Like A Leaking Intake Gasket. I Had A 95 Monte Carlo With A 3.4 L Engine. It Did The Same Thing When Cold. Repalced The Intake Gasket Which Fixed The Problem. That Engine Seemed To Have A Lot Of Problems With Gaskets.
