Old 01-06-2005, 02:07 PM
2CrX's Avatar
2CrX 2CrX is offline
Talking mini me compression
can any one tell me exactly how much the compression ratio goes up on a mini me swap. I am buying a crx Si motor that has been bumped up to 10.5 to 1 with arias pistons and crower rods. So I know the internals are strong and can hold quite a bit. Any help would be much appreciated.
Old 01-07-2005, 12:39 AM
arodg25's Avatar
arodg25 arodg25 is offline
Re: mini me compression
i think compresion goes from 9.1:1 on the si to something like 10.5:1 on the mini me so you'll probubly end up with something like 12:1. that pretty f**kin high
Old 01-07-2005, 01:23 AM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Yea, you might not want to get a mini-me swap, or change the pistons before you do 'cause you'll have to run race gas to get around lol
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 01-07-2005, 01:43 AM
Beater88 Beater88 is offline
Was that a6 head ported and polished too?
Dunno how much more the VTEC will add, even if it didnt have a 12.1cr with those pistons
A motor built with all that and a hot cam will put out easy 140-150hp
MiniMe on a normal a6 (not that good an upgrade, get a z6 block) will only get about the same
Old 01-07-2005, 07:46 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
You won't need vtec with high compression d16. Trust me. Get a cam and you'll be wondering why you keep smoking the tires through 3rd.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 01-07-2005, 02:00 PM
2CrX's Avatar
The compression would be pretty damn high. The head is untouched on the Si motor. Ill probably try to get it ported and a diff cam. Might get the head milled to bump up the compression a little. Would like to have about 11 to 11.5 to one. Thanks for the help.
Old 01-07-2005, 02:07 PM
Dang at 11 or 11.5 you will have to run high test with some additives or it will ping like a bitch.
Im surprised that someone went through the trouble of building the bottomend like that and didnt P&P the head, or get a good cam, kinda dumb...you never really realize the power of the motor untill you do everything.
Old 01-07-2005, 02:16 PM
2CrX's Avatar
My buddy has a B20 vtec running 11.5 to one. He runs hightest and has it tuned good, no problems. The guy Im buying the motor from started to go more to Show instead of go, so he never got the head done.
Old 01-07-2005, 04:37 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
if you run a z6 head, it will be approx. 11.4:1. If you run a y8 head, it will be approx. 11.7:1. This is all using a stock z6/y8 head gasket.
I say do it. Get some ARP head studs, some sort of fuel tuning/vafc, and a wild cam and go with the Y8 head...
compression calculator:
http://www.knology.net/~jediklc/D.htm
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 01-07-2005, 06:20 PM
2CrX's Avatar
What are the z6 and y8 heads off of? 11.4 soud pretty damn good. Thanks for the info
Old 01-07-2005, 07:40 PM
kccrxsi kccrxsi is offline
Send a message via ICQ to kccrxsi
Should be off of 92-95 Civic EX...
Old 01-08-2005, 10:39 AM
bambam89lx's Avatar
AF - Advisor
yep...z6 is off of a 92-95 civic ex/si and the Y8 is off of a 96-00 civic ex only.
Old 01-08-2005, 11:29 AM
2CrX's Avatar
I think ill start looking for one soon. Do you know if ones better than the other?
