Old 01-06-2005, 01:22 PM
tytgs300's Avatar
tytgs300 tytgs300 is offline
acetone it is right ?
ok this is my first time removing these decals. seems like acetone is what most ppl use in FAQ. my decals seem more like paint than just stickers, but i quess acetone will do. let me know what to avoid and what not ....tks
Old 01-06-2005, 08:53 PM
StygianMax StygianMax is offline
You might want to use non-acetone nail polish remover. I used that stuff from Walmart to remove the tampo prints from my Maisto CLK DTM (2002 version - Vodafone). It works like a charm. BTW, I used Q-Tips to rub off the paint. The non-acetone stuff won't harm the base layer of paint and that might just do the trick for your decals.
Old 01-06-2005, 10:55 PM
Gafoto's Avatar
Gafoto Gafoto is offline
Send a message via AIM to Gafoto Send a message via MSN to Gafoto
Re: acetone it is right ?
The problem with acetone nail polish removed is it easly damages plastic. If you take apart the car and JUST have metal you shouldn't have a problem with it. Non-acetone can be used all over though.
Old 01-07-2005, 12:03 AM
nosliw2004's Avatar
nosliw2004 nosliw2004 is offline
Send a message via AIM to nosliw2004 Send a message via Yahoo to nosliw2004
would non acetone just be as effective as nail polish remover with acetone?
Old 01-07-2005, 11:10 AM
Gafoto's Avatar
Re: Re: acetone it is right ?
I think the non-acetone requires a little more elbow grease but its definetly safer.
Be careful with this stuff either way. If you keep rubbing one spot continously you can actually start rubbing the paint away. I usually work over a period of an hour or two and do little sections and then wash off the excess polish remover.
Old 01-07-2005, 01:21 PM
tytgs300's Avatar
i didnt know about non-acetone remover. i wiped out some paint on the metal as well as on the plastic lip. now the lip has a faded look to it. kinda like a weathered version.
