Old 01-06-2005, 11:13 AM
fenwickc fenwickc is offline
Air Conditioner Compressor
Help - I've got a '91 Voyager that I'm trying to bring back from life support. I've been told that the AC compressor has seized up and needs to be replaced. The only sympton is a very grinding sound - belt or pulley??. I don't want to replace the compressor - is there any way to bypass the AC (cut it off) and continue to drive the car? I've been told this is possible by a friend but can't find any info. Thanks.
Old 01-06-2005, 04:00 PM
yogi_123rd yogi_123rd is offline
Re: Air Conditioner Compressor
It's OK if you remove the V-belt to disable the compressor. Car should run fine without it. Just don't put the AC on. When compressors seize, the belt usually rips off anyway.
Old 01-06-2005, 06:40 PM
Re: Re: Air Conditioner Compressor
thanks for replying but I'm still a little confused - the guy I spoke with said that the belt had to be re-routed not just removed (would have to purchase a different belt). Can you give me any more details about your idea?
