Old 01-06-2005, 10:40 AM
stevedad25 stevedad25 is offline
Clunking along in 4x4
About three days ago I started to notice a clunking sound coming from the drivers side wheel on my 98 Sport. It's most noticable when turning the wheel in 4 wheel drive but I have also heard it when starting to drive straight from a stop, about 10 feet into it. I thought it could be the wheel bearings or ball joints but when I'm not in 4x4 it's fine. I'm thinking CV joint. I know the Cherokee are known for their short turning radius and that this causes the front end to "hop" while turning in 4x4. It is not due to this. It is a definite clunk which is more pronounced when turning.
Thanks Steve
Old 01-06-2005, 12:45 PM
gtmud gtmud is offline
Re: Clunking along in 4x4
Check your U-joints in the front axle, good chance that they are gone. If so, easy replacement. Either pull the axles and take them toa machine shop to have the old cups pressed out, and the new joints installed. You could do it yourself, but I recommend the first way, just make sure that the jiont works freely, no binding at all!
Old 01-07-2005, 03:34 PM
mx52nv's Avatar
mx52nv mx52nv is offline
if it is the wheel hub bearings, you would get a lot of road noise as well during normal driving, and more noise around corners. start with the cv joints, which are cheaper than new wheel hub assemblies.
current rides:
1990 Turbo Miata
lifted and locked 96 Grand Cherokee with other toys under the hood
retired rides:
1996 Eclipse GSX
1991 Stealth
1991 Porsche 993 C2
1988 BMW 520i
Your SUV isn't a Jeep, and my Jeep isn't an SUV....
SCCA, where you actually learn to drive
