Old 01-06-2005, 10:38 AM
rikka65 rikka65 is offline
Question noise from wheel?
I recently bought a '94 blazer lt.Soon after I bought it the wheel studs broke off while driving.I thought that the wheel must have been loose,so I replaced the studs.Now there is the same noise coming from the wheel as there was when the studs broke before.Could it be some sort of joint or bearing?Everything looked Ok when I replaced the studs.
Out of Ideas.
Thanks
Old 01-06-2005, 02:25 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: noise from wheel?
Be more specific, we don't know what noise you are talking about , when it happens and what drivability problems it causes.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-07-2005, 03:49 PM
the noise is kind of a whoop whoop whoop every time the wheel turns,but it does not do it all the time.It does not cause any drivability problems it just makes that irritating noise.
Thanks
Old 01-08-2005, 01:51 PM
BlazerLT's Avatar
AF -Advisor
Yip, sounds like a bearing to me or maybe a shifted belt in the tire.
Also, hope you didn't over torque you wheel on.
You are only supposed to use 100 ft/lbs max.
