Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-06-2005, 10:30 AM
jibbijib's Avatar
jibbijib jibbijib is offline
Send a message via MSN to jibbijib
Cleaning a Turbo
Is it possible to clean a used turbo? If so, how would one go about cleaning it? Are there certain chemicals that can be used and what way are they to be used? Would i have to oil the turbo after cleaning it? Is there a certain type of oil that a turbo takes, and what kind? Im talking of the compressor, not the exhaust side. The exhaust side is detached. Please let me know if this is possible. Thanks much
Old 01-11-2005, 05:47 PM
jibbijib's Avatar
Re: Cleaning a Turbo
Someone has to answer me, like come on
Old 01-12-2005, 08:31 PM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
on the last turbo that i cleaned (greatly used), i took of the comp side, then turbine side, the middle section got taken apart to where it was just the center housing. Then i took the compressor side, turbine side, back plates, and took them into the glass beader. I like using this much more than a sandblaster, and after the glassbeading, i put them into a high pressure, high temp water cleaner. I also bought a used center section off of ebay, put it all back togethor, painted it (for looks) then auctioned it off. If you dont have these things available to you (glassbeader, water cleaner) then i dont really have a very good suggestion to you. Good luck!
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 01-12-2005, 09:03 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Make sure the entire blade is cleaned thourougly. If not, the wheel will be off balance.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 01-12-2005, 10:01 PM
yea i forget to mention the actual blades, i love glassbeading though. If you cant do it your self, see if someone you know can..My RHG6 was crap, covered in rust and looked extremely bad, glassbeading and high pressure water and it looked brand new..
1988 conquest TSI
Torque wins races!
Old 01-14-2005, 07:03 AM
jibbijib's Avatar
can glass beading be put in a sandblaster, or does it have to have its own container. I dont want to sandblast, it makes more work because it leaves a rough surface.
