Old 01-06-2005, 10:15 AM
BB1970's Avatar
BB1970 BB1970 is offline
Angry remote door locking
anyone know of a good reliable place i can get a central door locking remote keypad for my 1st gen gto?
iv'e got all the numbers off the old one and as far as i can tell its the same as a std 3000gt 1st gen.
I got a price from my dealer and nearly fell over.(£186+vat)
I need the supplier to be from a trustworthy source as im from the uk and need it to be shipped over.
Any input would be appreciated
thanks
BB
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 01-06-2005, 11:31 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
I might just be having a slow day, but are you talking about the FOB?
If you are then I know of this from Dave Blacks site http://www.daveblack.net/asp/3SiFAQ.asp I am not sure what the price is now, but sending an email to ask for the price is pretty easy. Instead of Libertyville, I use Wayzata Mitsubishi http://www.wayzatamitsubishi.com/en_US/ for my parts ordering. They've been pretty good to me with their pricing.
Q: Where can I purchase a remote for keyless entry?
A: New remotes for keyless entry can be purcahsed from Libertyville Mitsubishi at (847) 816-6660 for approx. $25 plus shipping.
Q: How do I program the remote for keyless entry?
A: Programming the keyless entry receiver will be required when you purcahse a replacement "FOB" or keyless entry remote unit. The keyless entry receiver is located behind the rear interior panel near the drivers seatbelt (drivers side). Here are the steps for programming your remote for keyless entry:
    1. Remove the rear hatchback cover
    2. Remove the rear seat:
      1. Pull the two handles near the center of each seat section on the bottom portion of the seat
      2. Lift the seat bottom upwards and set aside
      3. Remove the two 12mm bolts at the base of the rear seatback on the drivers side
    3. Remove the driver's side rear panel:
      1. Remove the rearmost screw on the plastic strip that sits over the rocker panel
      2. Remove the screw on the cover of the rear seatbelt retractor then remove the cover
      3. Remove the screws holding the seatbelt harness from the frame. This can be tricky since there is little room to work with. Use a stubby screwdriver
      4. The seatbelt itself does not need to be removed. You can just remove the harness and leave the seatbelt threaded thru the panel
    4. Remove the screws closest to the rear of the car that are located on the plastic header and footer around the drivers doorframe. These typically overlap the rear panel by a small amount and may need to be loosened to move the rear panel
    5. Behind the rear panel you should see a box in front of the rear speaker - this is the receiver unit
    6. Remove the receiver from the car body
    7. Find the switch labeled SET 1 - FIX - SET 2 and move the switch to either SET position. (the two SET positions are in case you have two transmitters with different codes)
    8. Press any button on the remote transmitter
    9. Move the switch back to the FIX position
    10. Test the new remote transmitter
    11. Reconnect everything making sure that the antenna connector is tightly connected to the receiver
Resistance Is Futile (If < 1ohm)
Old 01-06-2005, 11:46 AM
BB1970's Avatar
Re: remote door locking
yes i did mean the fob, thanks yogs i take they will ship, i will contact them.
regards
blitz dome filter
sachs clutch
Old 01-06-2005, 12:28 PM
BB1970's Avatar
just tried to email them but as i dont have a zip code it wont let me complete the form!!!!!
doh!!!!!
if anyone has a direct e mail address it would be appreciated
thanks.
blitz dome filter
sachs clutch
Old 01-06-2005, 01:27 PM
YogsVR4's Avatar
Here is the email for Brian Huntington at Wayzata [email protected] Its been several months since I emailed him, so I'm not positive he's still there.
Old 01-06-2005, 03:09 PM
BB1970's Avatar
thanks again yogs i will try him tonight
blitz dome filter
sachs clutch
