Old 01-06-2005, 07:47 AM
nathan9876wolf nathan9876wolf is offline
Red face Water on Passenger Side Carpet
I have a 2000 Grand Prix and I have been noticing when it rains, water collects on my passenger side carpet (under the floor mat). I'm not certain how the water gets there. I recall someone telling me that a seal might be loose near the windshield. I haven't took anything apart to try and locate where the water is coming from. Has anyone had this same problem?
Old 01-06-2005, 08:42 AM
TorinoGT69's Avatar
TorinoGT69 TorinoGT69 is offline
Automotive Master
Send a message via MSN to TorinoGT69
Re: Water on Passenger Side Carpet
If it only does it when it rains it is probable the seal on the windshield, has the windshield ever been replaced?
Old 01-06-2005, 08:54 AM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Check A/C drain. Search for threads "passenger side". Should come up with a ton of threads on it.
Old 03-26-2005, 08:53 AM
gtped gtped is offline
I TOOK ABOUT 3 GALLONS OF WATER FROM MY PASSENGER SIDE RUG WHAT I FOUND WAS THE WATER DEFLECTOR/SEAL UNDER THE COWL PANEL WAS OUT OF PLACE AND AFTER IT RAINED THE WATER WOULD GET INTO THE HEATER BOX AND THAT'S HOW THE WATER GOT IN KIND OF AN EASY FIX.
Old 03-26-2005, 09:34 AM
BIG-L's Avatar
BIG-L BIG-L is offline
In the pic you will see a piece of rubber molding that may start to fall off.The clips get old and no longer hold the 6/8 in strip of rubber molding.That is what GM used to deflect water from getting in to the hvac box and then it leak's on the floor.To fix it clean the aerea that the rubber molding is on , use some 3M yellow window adhisive and place the molding back in place and let dry.That should take care of your problem.
~Larry~
ClubGP Member 6530
Since 2001
