Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 01-06-2005, 03:49 AM
EDOG25 EDOG25 is offline
Ebrake stuck on
Can someone tell me how to disingage the ebrake because my car feels like the ebrake is stuck on all the time ???
Old 01-06-2005, 07:39 AM
ZX2000 ZX2000 is offline
Re: Ebrake stuck on
push the button on the end of the handle and let it go down? maybe?
Old 01-06-2005, 01:13 PM
Re: Ebrake stuck on
Ha ha ha... I ment the cable
Old 01-06-2005, 03:43 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Ebrake stuck on
Just see if you can push it in nuetral on a flat surface. If so, the brakes aren't your problem. If not, you'll have to determine which wheel is binding. Sometimes you can tell just by feeling which wheel seems hotter after driving some distance.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 01-08-2005, 07:36 PM
I know what wheel is sticking now.... I just need to know how to release the e brake cable ??. "I dont want to cut the cable if I dont have to"
Old 01-10-2005, 01:21 PM
Re: Ebrake stuck on
There is usually, on most cars, an adjuster thread and locknut type of thing on the cable, possibly under the cover for the e-brake handle. You back it off until the cable relaxes. But if one rear wheel is binding, the problem is probaby in the hardware of the brake set itself, not the cable.
...empty gun rack.
Old 01-10-2005, 01:22 PM
Re: Ebrake stuck on
A broken return or holdown spring in a drum brake can cause this.
...empty gun rack.
Old 01-10-2005, 10:24 PM
Thanks for the info..
Old 01-11-2005, 11:51 AM
Todd R Todd R is offline
Re: Ebrake stuck on
I know what it is, I have the same problem with mine.
The joint on the lever where the E brake cable hooks to rusts and binds up. Fron the back side of the hub tap it with a hammer to break it free. You will have to disassemble the unit to free the joint up for good. Take the joint apart, wire brush off the rust and coat everything with assembly lube or some other lubricant that won't was off easily.
TR
Old 01-14-2005, 12:52 AM
Thank's for the info... My ebrake cable is not so much rusted as frozen I think The Rain got it wet then froze.
