Old 01-06-2005, 02:14 AM
S10 Blazer 4X4 94 S10 Blazer 4X4 94 is offline
Starting Problems 94 S10 Blazer 4x4
If anyone could help it would be greatly appreciated!!! My blazer started having problems starting, it turns over and gets like 1 quick shot of gas and fires but not enough to start, usually take 10 or more times of turning it over to get it started and once it does start as long as its warm it will start with no problem, i have replaced the battery and gas filter so far and i still have the same problem can someone maybe help me out? Thanks
Old 02-11-2005, 08:52 PM
a454nova a454nova is offline
Change your fuel pump.
Old 08-03-2005, 12:57 PM
neojato neojato is offline
Hey 'S10 Blazer 4X4 94', did that fix your starting problem??? Curious b/c I am also experiecning the same thing and I have replaced the battery, battery cables, starter,... but not the fuel pump. Let me know if it worked or not. Thx
Old 12-05-2005, 09:01 AM
GoldBuFu89 GoldBuFu89 is offline
Re: Starting Problems 94 S10 Blazer 4x4
I Have the same model Blazer and after a new fuel pump, spark plugs, spark wires, egr valve, fuel system cleanout and two red top optimas my truck still turns over about 10 times before it fires barely enough to start. If you have solved the problem please inform me.
Old 04-22-2008, 02:53 PM
redmurphy redmurphy is offline
have you tried check the timing
Old 10-15-2008, 07:22 PM
s10 blazer94 4dr s10 blazer94 4dr is offline
hi i have a 94 s10 blazer vortech cpi system and you problem is that the injector lines on the inside of the intake are worn out and have made a hole in it thats what happened to mine and now it starts fine the part cost about 300 from advance auto and 600 from gm and it dosent take that long to do
Old 02-16-2010, 12:40 PM
cardude59 cardude59 is offline
Talking Re: Starting Problems 94 S10 Blazer 4x4
i would suggest that you test your engine coolant temp sensor also. i had c1500 with the 4.3 and it was a hard starter. i tested the ect and found that it rear 200 degrees all the time.i relaced the sensor and problem solved. good luck!!
