Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 01-05-2005, 11:09 PM
importeater5_0 importeater5_0 is offline
Send a message via AIM to importeater5_0
tweecer
ok i hear good things about this programmer, but i have a few questions about it. How much hp gains would i be able to get from using the tweecer on a mildly modified 5.0, and also can someone who knows about cars but isnt to knowledged about air/fuel ratios, and stuff like that, be able to use this tweecer and not fuck something in their car up?
Old 01-06-2005, 04:56 AM
Future303 Future303 is offline
Re: tweecer
I don't have the Tweecer, but I have its cousin, the EEC Tuner.
The codes are the same, and the EEC Tuner can do almost everything the Tweecer can do.
I also happen to have an almost stock engine, other than some basic bolt ons. Pretty much the only two things you can play with are Ignition Timing and Air Fuel Ratios. Nothing else will really have much effect on performance on an almost stock engine.
You may be able to get up to 10hp extra from a good tune, don't expect more than that.
Also it takes a LONG time to be able to understand the Ford EEC and you have to be real careful about what you edit. Make a mistake like leaning out the fuel mixture too much, or screwing the injector timing and boom, you grenade your engine.
If you're up to learning a lot about your EEC and you have the patience to slowly make mods, a Tweecer/EEC Tuner is a good purchase, especially if you plan to do more upgrades to the car (Like me).
If you plan on keeping the car stock then a Tweecer is probably too expensive for the benefit.
95 GT AKA "The Purple Hippo". Stock 302 bottom end. Edelbrock Heads. Performer 5.0 Intake, 1.7 RR's on stock Cam, Stock T5, 3.27 gears, UD Pullies, K&N Filter, rubber boot deleted, A/C deleted, BBK Catted X-Pipe, 180º TStat, EEC Tuner running J4J1 stock BIN. AEM WB02, Minor tunes, running pig rich. No clue as to RWHP feels a tad faster than a stock 05 GT.
Old 01-06-2005, 09:15 AM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: tweecer
I bought one, since it will help me considerably with drivability, and some other things, such as:
I can load in the timing/fuel curves out of an A9L. Voila'! PIH with half the work!,
I can delete the EGR function completely out of the computer, so it won't throw a code when I take it off, and it won't ping because the extra part-throttle timing won't be there.
I'll be able to set the MAF properly when I switch back to 24 lb injectors...
I can revise my fan scheduling to keep her cool, and eliminate my "hot wire".
Plus, I'm going nitrous soon, and the extra "TwEECing" will be extremely beneficial then.
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 01-07-2005, 12:34 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: tweecer
For a mild 5.0, I would put my money some where else.
Aaron,
I shipped it yesterday Enjoy.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 01-08-2005, 12:23 PM
Re: tweecer
thanks, ill probly wait a bit before i do any chips or tuners
