Old 01-05-2005, 11:05 PM
tjr05 tjr05 is offline
Unhappy no spark from coil.....
I have a 1992 plymouth voyager and it just up and quit on me while driving. You can hear the fuel pump come on and the starter engages. there was no spark coming from the coil so I changed it and it still isn't starting. I tried a new wire but that didn't help either. Can someone please HELP ME with this. I don't know what's wrong?? Is there fuses under the hood? is there a coil relay or fuse that I'm missing? If so where is it located....?It has a 3.0L engien automatic
Old 01-06-2005, 09:49 AM
yogi_123rd yogi_123rd is offline
Re: no spark from coil.....
Your Ignition system consists of two signals that go to the ECM. The ECM controls the spark/coil.
1. The crankshaft position sensor (CPS) is used to to find TDC of number 1 cylinder. If no signal, out of time - no spark. Located on front end of motor by crankshaft. This is the most common reason for no spark.
2. The distributor has six magnets on the rotating shaft and a one magnetic pickup on the housing for sending a signal. Possible causes are bad pickup in the distributor or a broken wire.
Old 01-06-2005, 12:27 PM
Thanks so much for the help. I'll check that stuff out.
