Old 01-05-2005, 09:45 PM
will2shower will2shower is offline
Send a message via AIM to will2shower
carb question
Ok im looking for a good carb for my 72 chevelle, 350 stock heads .224 .234 dur, .466, .488 lift cam. 4 speed manual trans. i will be reving to aroung 5700. I figure i will be looking at around a 650 cfm carb so i have a little room to build. From what i have read having mechanical secondary's is a good thing with a large cam.. but i also want to have a electronic choke. is my thinking correct? im looking at demon carbs as well...
Old 01-06-2005, 08:18 AM
MrPbody MrPbody is offline
AF -Advisor
Re: carb question
For a mild engine such as you describe, I believe you would be best served by a Holley 650 vacuum secondary, or a well prepared Q-Jet.
Demons are Holley "knock-offs", and have been known to use misleading information in their advertising and ratings. A "650 Demon is not really rated at 650. it's more like a Holley 750, but by using the smaller number, they let you ASSUME it's a rating. FWIW, at the Indy Nats, I looked at the BG pro stocker. Holley carbs...
Old 01-07-2005, 06:35 PM
nova68 nova68 is offline
what do you mean demons are holly "knock offs".
Old 01-07-2005, 10:08 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: carb question
I believe he means that Demon carbs use the same modular design as Holleys and can use some of the same tuning parts.
Demon carbs supposedly do not have some of the minor problems that Holleys have, such as using a check ball to reduce the change of a carb backfire from rupturing the power valve.
Old 04-22-2005, 12:27 AM
Vortec350S10 Vortec350S10 is offline
Re: carb question
I think having a manual you would be OK with a mechanical secondary carb, and finding one with E-choke shouldn't be to tough.
'89 S15 4x4 350TBI/700r4
restored body, paint,
3" lift, crane cam, vortec heads
'88 Iroc 350 carb, TCI 700r4, 380hp
Old 06-19-2005, 02:46 PM
NOVA71's Avatar
NOVA71 NOVA71 is offline
You are bang on with the Demon 650. I had a Holley and it worked great. I just recently bought a 650 Demon With vac. secondaries and an electric choke and I love it. It works way better than my Holley did. I had the Demon apart to change the jets and they are made much better than the Holley also. Billet base and billet metering plates. Just my opinion though.
