Go Back   Automotive Forums Car Chat > Games > Need for Speed Series
Old 01-05-2005, 10:43 PM
Dustin_S's Avatar
Dustin_S Dustin_S is offline
Send a message via ICQ to Dustin_S Send a message via AIM to Dustin_S Send a message via MSN to Dustin_S Send a message via Yahoo to Dustin_S
Tuning cars & 3000GT 1/4 times
Does tuning the cars in-game actually make a difference? I've played around with the tuning and while I'm still mostly in the dark, I know the difference between a camshaft and a shift knob...However, I've only succeeded in making my car slower. Does manual tuning change ANYTHING for the better?
Also, what's the fastest time possible with the 3000GT?
I've gotten 9.11 with 5 perfect shifts and one overrev.(1st to 2nd is about a tenth of a second long, someone can back me up on that- it's CRAZY)
Any suggestions for bringing that time down anymore?
Old signature is old.
Old 01-06-2005, 12:02 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Re: Tuning cars & 3000GT 1/4 times
tuning is vital if you wanna do well. i got my 350Z to run 7's & 8's. you gotta see what rpm you land at after shifting at redline. from there start setting your power to arrive a littel before that so that you're always in your best power range, by adjusting your air:fuel ratio. then once you start making good power set your turbo to make full boost later. you don't need your turbo spooling between 1000 and 3000 rpms if you're only in those rpms for one gear.
other than drag racing the dyno doesn't help very much because it only shows the peak power. set your hp and tq to arrive at the rpms you'll need them most depending on which event you're doing. drift and street X you want your power arriving early and tapering off before 6000+ rpm or so because you're not trying to attain top speed.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 01-11-2005, 11:05 PM
XeVeNskyLiNE's Avatar
XeVeNskyLiNE XeVeNskyLiNE is offline
Turbo makes me emo!
Send a message via AIM to XeVeNskyLiNE
ditto. tuning really does matter. i've fine tuned my drift car from everything to gear ratios, suspension and downforce, now i'm ranked 45th (last time i checked)in the world drifting online, woot woot.
_______A-10 Aircraft Armament Systems Apprentice vv Can't get my sig right vv
Currently in Davis-Monthan AFB, Arizona MySpace My S14 and DSM
Old 01-12-2005, 01:15 PM
Alastor187 Alastor187 is offline
Re: Re: Tuning cars & 3000GT 1/4 times
When you start the dyno and you see the car revving up dont hit any buttons and let the car get into third gear. After that the power and torque graphs should be generated, and if you run multiple tests it will overlay the previous run with the current for comparison.
|_|_|_|_|_|_|_|_|_|
