Old 01-05-2005, 09:23 PM
gonzales7727's Avatar
gonzales7727 gonzales7727 is offline
Car Temp
Hey fellas, got a question.
I live in phoenix and i notice that my car doesn't really get up to normal temp (195) latley.
It's been around 165 and i was wondering what you guys think, maybe the thermastat is stuck open, but I changed it in the begening of the summer, and I also notice that my heater either takes forever to warm up and when it does it's nothing like it used to be.
thanks fellas
Old 01-05-2005, 11:14 PM
leeder70 leeder70 is offline
Re: Car Temp
having the same problem.
gonna check the heater coer and make sure it aint plugged
Old 01-06-2005, 12:22 AM
papi62596's Avatar
papi62596 papi62596 is offline
Send a message via AIM to papi62596 Send a message via Yahoo to papi62596
Re: Car Temp
Check out your heater core. You can run a garden hose to it to make sure it is not plugged.
Old 01-06-2005, 05:40 PM
public's Avatar
public public is offline
Re: Car Temp
Your thermostat is stuck open. Even it is new. Some of the aftermarket ones are not real good.
Yes, I am retarded.
Old 01-06-2005, 08:05 PM
Re: Re: Car Temp
never done that before, how would i go about that, also it's a 1996 Z-24
Old 01-06-2005, 08:56 PM
hackken hackken is offline
Re: Car Temp
I agree with public, some of the aftermarket thermostats are garbage. I have had good results with Stant thermostats.
Old 01-07-2005, 10:58 AM
Langning Langning is offline
Re: Re: Car Temp
I have the problem when driving at highway at speed > 65mpg, the temp needle would stay at mid-point between "C" and the center and at colder winter now, it dips even lower... For city driving, the needle stays at center. My car is 96 Cav 2.2 LS and I just replaced the thermostat, hoses, and water pump. It too takes long time to warm up to center in cold mornings.
I don't think my thermostat is stuck open. I did touch all the hoses when idling: the upper hose (outlet?) is always hot; the lower hose (return?) is cold and sometimes warm; the smaller hose (heater? next to thermostat and goes to the back) is always hot too. The thermostat sit at the top end of lower hose & heater hose and 1 is hot & the other is cold, this indicates that the thermostat is closed.
I can idle the car as long as I can, the needle never move pass the center. The fan is never on after I put in the autozone fail-safe 180 thermostat. I may had 70% coolant/water mix (after I poured the whole bottle of coolant in and it took only another 2 qts of distilled water)... Very strange on my Cav as my other GrandPrix or Equinox the temp always stay at the same spot regardless of outside temperature or driving speed.
I am less concerned with the low temp as my car's temp was on the high side before I did the works.
Old 01-07-2005, 04:31 PM
public's Avatar
Re: Car Temp
If your heater hose is hot BUT you have no heat your heater core is blocked or the baffle in the dash is stuck. Your termostat may be stuck partially open. This plus the bypass hose can be enough to over cool.
Yes, I am retarded.
Old 01-07-2005, 06:13 PM
noshun's Avatar
noshun noshun is offline
Re: Re: Car Temp
The wire controlling the heat dial-to-heater may have even worked loose meaning the dial turns but it doesn't do anything!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
