Old 01-05-2005, 09:11 PM
etsad etsad is offline
Error code 14
Hi all, replaced engine and I got the check engine light on after 5min of operation. Car runs good 'cept for a "hunting" idle after the engine is warmed up. Error code 14 is for the 'Coolant Temperature Sensor circuit. High temperature indicated.'
huh?????
I haven't had the car over heat. in fact the temp gauge always is on the cold side of middle.
Couple of questions. 1 where is the blasted thing? 2 what does it do?
does this affect my hunting idle?
Thanks for the help/insite
Steve
Old 01-05-2005, 10:18 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: Error code 14
its screwed into the upper side of the throttle body under the air cleaner housing, look for 2 small water hoses that go the the throttle body, sensor is between them. if it goes bad the idle will cycle up and down
Old 01-06-2005, 03:30 PM
Re: Error code 14
How may wires are there?
I have a sensor under ther air cleaner as discribed AND I have a sensor next to a small water line 3/8" od from intake to throttle body.
the sensor in the intake does not have a wire connected and I cannot locate one either.
Could you provide a pic? email to [email protected]
Thanks for the help. I DO appreciate it!
Steve
Old 01-06-2005, 05:45 PM
Crvett69's Avatar
Re: Error code 14
its in the throttle body assembley, not the intake manifold, has 2 wires going to it. the one that has no wire going to it in side of intake is mostly for automatic cars
Old 01-06-2005, 06:07 PM
Re: Error code 14
Thank you for the clairifacation. I'll go and play with it.
Thanks again
Steve
