Old 01-05-2005, 09:45 PM
NATIONAL87 NATIONAL87 is offline
94 Cavalier Blinkers not Working????
The flashers will work but the blinkers will not..not even a light on outside or inside on the dash..only on flashers..I changed out a relay next to the flasher relay which is suppose to be the blinker relay..still nothing & fuses are all good..I cleaned blinker switch but didnt look bad & still nothing..any ides?
Old 01-07-2005, 05:51 PM
BostonGuy - 001 BostonGuy - 001 is offline
Re: 94 Cavalier Blinkers not Working????
I have a manual, I will look for the circuit for you. You should be able to troubleshoot it by bypassing different switches as seeing if that works. Will check and post back.
Old 01-07-2005, 07:08 PM
noshun's Avatar
noshun noshun is offline
May be the swith on the stalk at the steering column!
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
