Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-05-2005, 08:40 PM
SLoe's Avatar
SLoe SLoe is offline
Ecu
The ecu on a manual is different from that of an automatic right? Is it different for a gsx than a gst?
Old 01-06-2005, 10:29 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Ecu
No, according to DSMLink's website it doesn't matter what car you get it from. 5-speed, automatic, AWD or FWD. For the automatics there is a seperate tranny control computer.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 01-06-2005, 04:28 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Ecu
it doesnt matter IF you are getting dmslink or a chip. if you are staying stock then you need the right ecu. the fuel trims, timing maps, injectors etc.. are different but if you get a chip they change all of those anyway
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 01-07-2005, 07:05 AM
Re: Re: Ecu
Just out of couriosity, why would it matter? As long as he didn't get one from a gs. The motor is the same so the trims, etc would be the same.
1997 Spyder GS-T
5-Speed
Old 01-07-2005, 07:57 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Ecu
Auto 1Gs use 390cc injectors, where all other DSMs run 450s stock. So you would end up with AFR being way off. The only difference I'm aware of between fwd and AWD is the speed limiter, and that may only be a 2g thing.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-07-2005, 08:23 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Re: Ecu
If the limit is supposed to be under 155, it must be a 2g thing.
Kris
2012 Genesis Coupe 2.0t
Old 01-07-2005, 02:34 PM
SLoe's Avatar
I am sorry I wasn't specific. I have a 96 gst, so I know that a 95 or sooner won't work, but I found a computer from a 96 gsx and wondered if that would work.It is an automatic.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 01-07-2005, 09:30 PM
AF - Advisor
Re: Ecu
That will work fine. Another thing to note is that the 95-96 ECUs are the same (aside from the whole EPROM thing). If you swap between them and the later 2Gs, the firing order changes (the phase of the CAS signal to be more correct) and you have to swap plug wires around. The only difference between 2g auto and manual trannys that I know if is the input for the park/nuetral safety switch, which manual tranny cars make use of for the sutter box clutch switch Yes, should be interchangeable for a 2g.
Kevin Jewer
Old 01-11-2005, 12:54 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: Ecu
There is no difference between 1G awd/fwd jdm/usdm ecu's are there? I know a few guys who have done the swap and they have had no issues. Is there really underlying issues, or no?
"You can have everything in life you want if you will just help enough other people get what they want."
Old 01-11-2005, 01:00 PM
Re: Ecu
The "JDM" ECUs may have the code to actuate the Cyclone manifold, but I think there is no other difference.
Kris
Old 01-11-2005, 01:19 PM
bighauns's Avatar
Re: Ecu
Yeah, so as I expected there is not an huge issue with it then, correct?
Old 01-11-2005, 01:22 PM
Re: Ecu
Nah, it will just activate a solenoid that doesn't exist.
Kris
Old 01-12-2005, 07:34 AM
AF - Advisor
Re: Ecu
SImilar to situations like adapting the 2g ECU to the 1g car. The 2g has WAY more outputs/inputs, they jsut dont get used. Now, the ECU may be wondering whats going on with those inputs, but this is typically done with DSMlink so you just tell the ECU to not look at those inputs and stop being a pussy/drive it on. Lando already answered the question, just thinking out loud
Kevin Jewer
