Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 01-05-2005, 08:03 PM
Retard324 Retard324 is offline
Send a message via AIM to Retard324
wont go into gear in
sometimes when shiftin it wont go into gear, an yes i do hav the clutch floored when this happens. i hav to take it out an leave it in neutral for a few seconds. happens in 1st and 3rd. i'll rev it an let out the clutch near the friction point an nothin it happens. anyone know why it would do this? my synchro in 5th is goin out too, dont know if that would make any diffrence
'93 Nissan 240sx
'90 Nissan 240sx - KAE-T? might go NA instead
Old 01-05-2005, 10:03 PM
CocaColaEatsPie CocaColaEatsPie is offline
Send a message via AIM to CocaColaEatsPie Send a message via Yahoo to CocaColaEatsPie
Re: wont go into gear in
I am having the same problem in first. Sometimes I just have to jam it in or wait a little while and screw around with it and it slides in. But it's not really a problem for me because it's only with first and I usually have time to get it in gear.
John 3:3
Jesus answered and said to him, "Truly, truly, I say to you, unless one is born again he cannot see the kingdom of God."
Old 01-05-2005, 11:03 PM
ruffusrex ruffusrex is offline
sounds like the clutch is going out. but i would check the the hydraulics just to rule it out. bleeding the hydraulics is just like bleeding the brakes. the bleed screw is located on the slave cylinder which is on the backside of the tranny (standing under car, looking forward of car). also check the gearshift and selector cable. make sure they're tight and not kinked anywhere, which rarely happens. adjustment to both cable can be done from the console by the shift lever. be careful, there are certain clearance you have to adjust them to so check with repair manuals for the specific clearance. the most obvious thing to do is to check, add, change your tranny fluid. trannies are pretty sensative as far as repair goes so atleast have it checked out by a professional tranny shop.
Old 01-06-2005, 02:16 PM
i was told it might be the release or throw out bearing instead. anyone know how much it would cost to replace it?
'93 Nissan 240sx
Old 01-19-2005, 10:47 PM
dalude_24 dalude_24 is offline
It might be your pressure plate. My lude was doing the same thing. I went ahead and bought the whole clutch kit. it ran me 167$.
Old 01-21-2005, 06:39 AM
dbebesi's Avatar
dbebesi dbebesi is offline
that's what happened to my car, and i eventually losy 1,3,and5. in my case the trans is junk, and i'm replacing it with a used unit.
Old 01-23-2005, 01:14 AM
its not doin it anymore, i dont understand how all that happened. but i am replacin the clutch soon anyway and havin my tranny rebuilt an the 5th synchro replaced, gonna be a little expensive but it'll be worth it.
'93 Nissan 240sx
