Old 01-05-2005, 04:26 PM
Hunter1 Hunter1 is offline
More 4x4 problems
A few months ago my 4wd stopped working. The 4wheel high doesn't try to engauge at all (no lights no nothing) the 4 wheel low light blinks for a few seconds but never engauges. I have replaced the vaccum lines, cables, encoder or shift motor, and the switch. I would welcome ANY advice on this matter. thanks in advance
Hunter
Old 01-05-2005, 05:25 PM
Fireplug Fireplug is offline
Re: More 4x4 problems
Year, body , miles, engine, little more info please
Old 01-05-2005, 05:27 PM
Oh yeah that may be helpful thanks.
1996 2door auto v6 LS trim
Old 01-05-2005, 09:43 PM
Sounds like a bad tccm Tranfer case control module
Any noise from dash area when you push the buttons for the 4 wheel drive
Old 01-06-2005, 10:40 AM
only in 4wd low. it sounds like a relay switch, nothing from 4wd hi. I cant remember if 4wd high has to be engaged before 4wd low
Old 01-06-2005, 10:48 AM
punkrockdario punkrockdario is offline
it doesnt
Old 01-06-2005, 02:19 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
So you are saying when you push 4hi nothing is heard or happens?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-06-2005, 08:38 PM
Yes that is correct NOTHING happens.
Old 01-06-2005, 09:06 PM
BlazerLT's Avatar
AF -Advisor
Sounds like the relay.
Old 01-14-2005, 09:34 AM
As it turns out a short in the switch across the 2hi connector will also burn out the tccm. New switch and tccm and I have 4wd back. Thanks to all.
Hunter
Old 01-14-2005, 11:09 AM
BlazerLT's Avatar
AF -Advisor
Sweet!
Old 01-26-2005, 09:18 PM
red94fourdoor red94fourdoor is offline
Send a message via AIM to red94fourdoor
What did everything cost you in the end?
Old 02-02-2005, 11:09 AM
I have about $250 in it plus about 6mos. of frustration.
Old 02-02-2005, 03:21 PM
Did you have to replace both parts? Where did you get these parts from?
Old 02-02-2005, 03:49 PM
I have a lot of good parts left over that I didn't need. sort of the trial and error thing. If you can email a list of parts that you need I will try to locate them. [email protected]
