Old 01-05-2005, 04:17 PM
millersoviet millersoviet is offline
Alpine 9835 Sound problems
I swapped from pioneer 6100 cd player to alpine 9835 but have had major problems with sound quality. The pioneer sounded great but the alpine doesn't sound as good. Would it possibly down to the alpine needing more power and a direct connection to the battery.
Old 01-06-2005, 01:35 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Alpine 9835 Sound problems
well first you have to describe what sounds bad about it....is there distortion? static? humming? no bass? no treble?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 01-06-2005, 12:16 PM
Re: Re: Alpine 9835 Sound problems
No bass up front which make it sound like the front speakers are out of phase with the subs in the boot. Treble becomes distorted at volumes over 22. Car also sounds reasonable when stationary and without engine running but generally most systems sound better this way. Pioneer head unit didn't suffer from any of these problems.
Old 01-06-2005, 12:27 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
The Alpine 9835 is a pure quality headunit. I highly doubt it is something wrong with the product itself.
Old 01-06-2005, 12:52 PM
sr20de4evr's Avatar
as for the no bass, check to see if you have a highpass filter on
for the distortion, that could be due to the amp clipping because of low voltage, which could be due to the crappy stock wiring. Running your own wire to the battery like Alpine recommends could be the fix for that.
'01 Black Sentra SE
'05 Silver WRX STi
Old 01-08-2005, 11:57 AM
Yep wired unit straight to battery sound quality improved 300%
Thanks for backing up my own theory.
