Old 01-05-2005, 03:19 PM
dagrck74 dagrck74 is offline
Send a message via AIM to dagrck74 Send a message via Yahoo to dagrck74
Question 79 Trans am leaks water off starter, help!!
Hi all, I have 79 Pontiac TransAm and it is leaking water off of the starter. Where do you think it could be leaking from.
The starter is located almost under the Driver.
Someone please help this is my girl friends pride and joy.
Old 01-05-2005, 04:01 PM
82KnightRider's Avatar
82KnightRider 82KnightRider is offline
I dont know much about 2nd gens but maybe its a bad water pump
Old 01-05-2005, 04:38 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
Re: 79 Trans am leaks water off starter, help!!
sounds like a freez plug or mabey even a head gasket or cracked block or head clean the motor really good and look closer keep us up dated
Old 01-05-2005, 06:18 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
my 80 model ta had a head gasket leak and it was doing that same thing
Old 01-05-2005, 08:23 PM
CreepingDeath94 CreepingDeath94 is offline
I was about to say, unfortunately it sounds like a head gasket. It might be a freeze plug in the back of the head or block, but definitely clean it up real well and see exactly where it is coming from off the block. It would be best to put it in the air when looking for this after its clean if you have access to a lift.
Old 01-07-2005, 12:27 PM
MrPbody MrPbody is offline
AF -Advisor
dagrck74,
You e-mailed me and I tried to respond. I got the failure to deliver notice. Either something wrong with the return address or the e-mail account is dead. I didn't ignore you.
I'm of the opinion, if it's the 400 Pontiac engine, the expansion plug behind the starter, or the one in the end of the head (as creepingdeath94 said), is leaking. If it's the Olds 403 engine, it could be that, OR the head gasket. We rarely see the head gaskets leak externally on the Pontiac, but have seen a few with the Olds.
Jim
