Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-05-2005, 03:02 PM
KPot2004 KPot2004 is offline
running rich
i recently replaced the timing chain on a 1994 saturn sl2, everything is back together and now the car is def running really rich, it will idle good and starts up right away. but after like 5-10 seconds it will bog down for some reason and sometimes it will shut off. also the spark plugs are fouling out really, really quick.
compression is good in all cylinders, and it has brand new spark plugs
Old 01-05-2005, 03:03 PM
Re: running rich
also egr is working good and there are no trouble codes set.
Old 01-05-2005, 05:45 PM
donkeyboy donkeyboy is offline
Re: running rich
you probably either advanced or retarded your timing i'm guessing you advanced it since you're getting too much fuel. check it out. pm carguy83 for any questions cuz i'm on my friends name
My Scubi IS Driven by What"s Inside!!!
Old 01-06-2005, 12:25 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: running rich
did you reset the PCM? did you replace the chain before or after is broke? any change in performance? if so, how?(high speed, low speed, accel, ect). i also am wondering if the timing is off. did you follow a how-to of any type? timed like this?- http://www.saturnfans.com/photos/sho...p/photo/15049/
also check the plugs, what brand did you use? gaped at 0.040? correct reach and heat range?
Old 01-06-2005, 11:03 AM
Re: running rich
it was after the chain had broke, the head was checked and the valves were all good, its timed like in the pic, i used bosch spark plugs, i have yet to drive it yet because i am in the process of doing the brakes
Old 01-06-2005, 12:32 PM
carguy83 carguy83 is offline
Send a message via AIM to carguy83
Re: running rich
bosch are pre gaped... did u buy the right ones?
1995 Gold Saturn SL2 -- RIP May 05
1991 Blue Subaru Legacy Wagon -- RIP Aug 05
1995 White Mazda 626 DX -- RIP Feb 07
1991 Black Volkswagen Jetta Carat -- Current
Old 01-06-2005, 11:22 PM
Re: running rich
if those are platuims, swap them out. they are crap, get a nice set of NGK v-power or AC Delco. if that doesn't help, check compression
Old 01-06-2005, 11:40 PM
Re: running rich
Old 01-06-2005, 11:41 PM
Re: running rich
even bad compression wouldnt bog it that much... it would have to be a pre existing problem before the chain went. and as for the platinums the +2's and 4's run too hot for our engines... my ngk's are awesome though.
Old 01-06-2005, 11:50 PM
Re: running rich
check the plugs next, then if you haven't you may want to replace the ECT
Old 01-11-2005, 02:39 PM
Re: running rich
well it turns out that the probelm was that one of the cylinders wasnt getting spark becaue of a defective ignition coil. well i replaced that and it still isnt running right, it set a code 22, tps. well i replaced the tps and its still setting a code 22, even after ic cleared the codes
any ideas??
Old 01-11-2005, 11:17 PM
Re: running rich
the TPS code is more common a wiring problem, make sure the connectior is tight, pins haven't backed out. do you have a multimeter?
