Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 01-05-2005, 01:19 PM
ksmaxey ksmaxey is offline
94 Dakota electrical problem
Since I have ruled out the fuel pump I am into the wiring under the hood.
I don't believe the ecm is getting enough power. The line from the battery is showing around 8 volts.
I found two fusible links under the washer reservoir - they both seem fine using a connectivity test. (I wonder though if they are partially bad and so not allowing enough power through.
Do you know of any other fusible links?
Any other suggestions.
Old 04-09-2006, 12:30 AM
Jon Teeter Jon Teeter is offline
Re: 94 Dakota electrical problem
What do you mean you ruled out the fuel pump.Is the problem that the fuel pumps not running?What is happening.
