Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-05-2005, 01:08 PM
mlaws mlaws is offline
Angry new batteries die very quickly NOT ALTERNATOR
after new alternator, new computor board and fuses checked I still have a dead battery after a day has gone by without running the car. Seems to be worse in cold weather. 3 different places are unable to find the problem.... Must fix myself Im resently unemployed PLEASE HELP!!!!!!
Old 01-05-2005, 01:43 PM
TorinoGT69's Avatar
TorinoGT69 TorinoGT69 is offline
Automotive Master
Send a message via MSN to TorinoGT69
Re: new batteries die very quickly NOT ALTERNATOR
Describe your problem further do you get any power from the battery or is everything just dead till you jump it?
Old 01-06-2005, 06:06 PM
public's Avatar
public public is offline
You have a bad connection SOMEWHERE.
Yes, I am retarded.
Old 01-07-2005, 07:19 AM
To discribe further.....Hmmm....There have been a few times that when I opened the door to get in and the interier and dash lights seemed dead. (MY dash lights go on when I open the door) I then tried to start and NOTHING. After leaving the car and returning the interier lights WOULD work but there wouldnt be enough battery to start the car......THEN I would come back with cables open the door again and no lights again....ARRRRRG!!!!!!!
a. There is some drain on the battery that noone can seem to find.
b. The interier and dash lights seem to indicate when the problem is going to accure.
Q? Should my dash lights be going on when I open the door?
Old 01-07-2005, 10:08 AM
dwalmop dwalmop is offline
sounds like a classic loose battery cable
Old 01-08-2005, 12:55 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Your dash lights shouldn't be coming on when you open the door. I would suspect a bad headlight switch or a bad instrument dimmer switch (NOT high/low beam dimmer switch).
Old 01-10-2005, 07:04 PM
autoforum autoforum is offline
Take an ammeter and determine what kind of drain you have after the battery is fully charged. (If you don't know how to use an ammeter, find someone who does.) Then you can pull fuses till the drain goes away or diminsihes substantially. The fuse that makes the difference is on the circuit that has the short.
Old 01-11-2005, 07:16 AM
Re: Re: new batteries die very quickly NOT ALTERNATOR
No tried that early on.......
Old 01-17-2005, 04:23 PM
...then it's something that isn't fused with a regular fuse, like a fusable link, if you measure a drain.
