Old 01-05-2005, 01:02 PM
boosz28 boosz28 is offline
gas coming out of carburetor
i just rebuilt my carburetor and put it back on the engine and started it....it started right up but i have gas flowing out of the top of the carb....is the float set to high or is there something else ,....i tried startng it several times and it kept doin it
Old 01-05-2005, 01:38 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: gas coming out of carburetor
you mean out of the venturi??????through the air filter???
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 01-05-2005, 02:26 PM
Re: Re: gas coming out of carburetor
sorry not to sure wut the venturi is but its comin out of this thing that is in front of the primaries .(if ur lookin at it in a car its closer to u then the primaries.....its higher of the base of the carb......hope this helps u
Old 01-05-2005, 02:57 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
is it in the seam were it goes together? you may have a fold or a small crease in the gasket
Old 01-05-2005, 03:13 PM
no its not out of the seal its like shooting out the top but not shooting out a whole lot kinda llike bubbling out
Old 01-05-2005, 03:32 PM
bigbadbowtie bigbadbowtie is offline
Fuel is coming out of your vent tube. That means your float level is set too high.
What kind of carb is it??? Holley,Edelbrock,quadrajunk
Ray In Bama
78Z 355 roller on the GAS.
Old 01-05-2005, 09:28 PM
quadrajet
Old 01-05-2005, 09:47 PM
CORE402's Avatar
CORE402 CORE402 is offline
your float is set too high, your needle valve is bad, or you are running with too much fuel pressure.
1973 Camaro
AFR 195cc heads
CNC Motorsports 383 short block
Comp Cams hyd flat tappet
TH350
Dual 3" exhaust (LOUD)
Corporate 10 bolt w/ all new internals and axles
Old 01-05-2005, 09:59 PM
89IROC&RS's Avatar
id have to agree with these guys, probly a bad gasket, too high float setting, or something along those lines.
Old 01-06-2005, 06:32 AM
i think its the high float but i hhavent had time to work on it and the weather sucks up here right now so next week i'll prolly do it
Old 01-13-2005, 03:47 PM
Waterman1963 Waterman1963 is offline
Try adjusting the float level first. After rebuilding a carburetor, it's a part of initial tuning anyway and just might be the problem. First, the car must be as level as possible. Remove the air breather/filter and look for the "sight hole". The sight hole is actually just a round, flat screw/plug on the passenger side of the float bowl. With the engine off remove the sight plug. Rags placed around the carb absorb fuel running out. With the sight plug removed, loosen the screw at the TOP of the float bowl with a large flat tip screwdriver. Just enough to be able to turn the 5/8 hex nut. Hold the screw in place when adjusting the hex nut. Turn the nut clockwise to lower the float level (which is what you want). Counter-clockwise raises the float level. This adjust the float valve assembly up and down in the float bowl. You want to lower the float enough so that the fuel level is just at the bottom opening of the sight plug opening, not flowing out on it's own. It should be able to run out of the hole if the car is rocked back and forth. If it does not, the float needs to be raised. After adjusting the primary float to what you believe is correct, repeat the procedure with the secondary float as well. Remove any gasoline soaked rags, replace them with fresh ones and start the motor. You can leave the sight plugs off while the engine is running as long as fuel is not still pouring out to fine tune the float level. With the engine idling and the float levels set, hold the hex nut in place and tighten the screw at the top. If gas still pours out or drips from the booster venturis at idle, you might have to replace the needle and seat assemblies. The screw and hex nut are attatched to the needle. Completely remove the screw at the top and pull the hex nut upward. You will pull the needle assembly out with it. The needles are available at part stores and are fairly cheap. I usually replace them automatically when rebuilding a carburetor. Don't forget to buy new gaskets for the hex nut. They are easily worn or destroyed when adjusting the float level.
Also turn the idle screw clockwise until you feel it begin to stop. Not too hard. Then turn it counter-clockwise 1 1/2 turns. This is a good basis to start from.
Good luck and keep us posted.
Old 01-14-2005, 12:05 AM
92rs25th's Avatar
92rs25th 92rs25th is offline
Send a message via MSN to 92rs25th
Let us know how it turned out.
I love rice so much , I eat it daily. Yum yum Civic.
1992 RS Camaro 383.
2004 Mazda 6.
2003 Subaru Legacy GT Limited.
1984 Nissan 300 ZX
1993 Mazda MX-3 ( Newest addition to my collection. )
http://photobucket.com/albums/y187/ohjiro
Old 01-14-2005, 12:36 PM
a few days ago i did redo the float level and i reassembled everything i started it and sit was running like crap ....it sounded like too much air was geeting in and u can here the sucking noise....we played with thetiming and all that and its running a whole lot better but its idling high...
