Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-05-2005, 12:42 PM
ANGEL61082 ANGEL61082 is offline
Send a message via AIM to ANGEL61082 Send a message via MSN to ANGEL61082
Unhappy Help!!just Bought 99 Rodeo;car Shakes When I Accelerate
I Just Purchased A 1999 Isuzu Rodeo Ls About Two Months Ago. It Has About 84,000 Miles On It And I Have Not Had Any Problems With It, Until Yesterday. I Went To Start My Car And I Noticed That The Check Engine Light Stayed On Once The Car Was Started. I Also Noticed That After It Had Started It Felt Like The Engine Was Shaking. I Turned The Car Off And Restarted It, And It Almost Didnt Start. The Weather Here Was A Little Colder Yesterday, But Ive Already Driven The Vehicle In The Snow And It Did Just Fine. So, As I Was Driving Home, I Noticed That When I Am Stopped And I Start To Accelerate The Car Is Very Jerky. This Also Happens When I Am About To Come To A Complete Stop. Along With This, I Also Noticed That I Have To Push Harder On The Gas Pedal For It To Accelerate Even To Just 30 Mph. It Still Goes Faster Than That But It Seems Like I Have To Put More Pressure On The Pedal That Usual....does Anyone Have Any Ideas As To What This Could Be? And How Easily And Cheaply It Could Be Fixed? Keep In Mind That I Am A Girl So When You Reply Please Try To Make Things Somewhat Understandable For Me!!! Lol!!
Old 01-05-2005, 03:12 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Re: Help!!just Bought 99 Rodeo;car Shakes When I Accelerate
Since you are getting a Check Engine Light, bring your vehicle to Autozone and they can scan your vehicle for "FREE". Just don't give out your phone number j/k
Once they scan your vehicles' computer, it should give you what part or sensor that is failing and narrow the problem quickly.
I would check the ignition systems like the spark plugs, etc. Clogged catalytic converter could cause the vehicle to have power loss and you have to push the gas pedal just to keep going at a higher speed.
Old 01-05-2005, 04:05 PM
johnsm johnsm is offline
Could be low or leaking tranny fluid. This will make the car shake until you get out of first gear. Check those codes.
Old 01-05-2005, 04:12 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Here are the main possibilities:
Leaking fuel pressure regulator:
http://www.geocities.com/endre_rl/isuzufaq.htm#faq22
Bad intake manafold:
http://www.geocities.com/endre_rl/isuzufaq.htm#faq5
Electrics are messed up (this is my guess). If you still have the OEM battery change it. Isuzu do funky things with weak batteries and alts.
http://www.geocities.com/endre_rl/isuzufaq.htm#faq61
Finally I could be as simple as water in the gas tank (add some of that iso-heet junk) or a plug fuel filter
http://www.geocities.com/endre_rl/isuzufaq.htm#faq16
I would start with the electrical first, then go to the fuel filter. But the first thing would be to get that code read. Head to the Zone! AutoZone ...
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-05-2005, 04:24 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Could also be a bad coil pack.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 01-05-2005, 06:43 PM
superfret78 superfret78 is offline
Sounds like a vacuum leak....intake manifold gasket maybe. Other than that, it could be a coil pack or the plug wires.
Old 01-05-2005, 07:37 PM
rodeo02 rodeo02 is offline
Like previously posted, you have to start by reading the OBDII codes. As a blind guess, I would say 1) EGR is stuck wide open, 2) Intake manifold gasket has a massive leak. If your check engine light is *flashing* on/off, you have a misfire, which is typically a bad coil or sparkplug.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
