Old 01-05-2005, 12:38 PM
FFHP.net FFHP.net is offline
Rebuilt B16a overheating, any ideas?
Here's a run down:
Engine threw a rod so we rebuilt it (professionally)
Engine now runs like a charm.
However, it's overheating.
All hoses are properly located
Coolent is good
Thermostat and water pump have been replaced with new
Top radiator hose fills with hot air as the engine overheats
Lower hose doesn't get hot at all
Heater hoses get no heat, and thus no warm air into car
We're tired of the car sitting on the lift, but we're doing the job for a friend and need to get it done.
Anyone have any suggestions we could try? I've searched through the forums enough and not found anything that's helped. Thanks for any help you can provide.
(Oh, one more thing, the engine was from a 95 Del Sol, DOHC VTEC if that is important)
Andy
Old 01-05-2005, 01:09 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
Re: Rebuilt B16a overheating, any ideas?
does the fan come on?
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 01-05-2005, 01:15 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
yeah check to see if the fan comes on. also could be air in the system. maybe have a bad heater core as well. kinda sounds like thermostat though. good luck
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 01-05-2005, 01:17 PM
Re: Re: Rebuilt B16a overheating, any ideas?
Yes, the fan comes on. Everything else works as it should. Here's an update.
The temp finally levels off after reaching 200 (on a 170 stat). Seems to be stable and under countrol. Still no heat in the car, we think the core rusted or clogged since it sat dry for about a month. Though there may be some problem we're not seeing that'll come up.
Thank You
Andy
Old 01-05-2005, 04:48 PM
ozzfreak ozzfreak is offline
I am far from an expert, but I had this exact thing happen to me when I bought a new thermostat. It was sticking shut.
Oz
Old 01-05-2005, 05:13 PM
travagliante's Avatar
travagliante travagliante is offline
hmm went the engine threw a rod how far was it bored out? Did you get oversized rings or pistons. Engines that have oversized rings tend to run much hotter!
Old 01-05-2005, 06:02 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
Oz
agree, even new ones fail like a Genuine Honda one that I bought and only lasted a week.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 01-09-2005, 02:35 PM
kris's Avatar
kris kris is offline
Off playing with fire.
They do? Never heard that one before.
Try burping your coolant system a little better.
Old 01-09-2005, 03:20 PM
crx91's Avatar
crx91 crx91 is offline
you can check the rad cap. if that is bad it can effect the cooling system. buy a new one. go down the line with the cheapest and easeist things
