Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-05-2005, 11:00 AM
mkdavies mkdavies is offline
Question Finding a vibration in the front
95 SC2 - 149,000 miles
I have a vibration coming from somewhere the front end. It changes with the car speed and not the engine RPM.
It also gets louder when turning.
I have replaced brakes/rotors/hubs/struts.
I jacked up the front and removed the wheels and ran it up to 3k
but can not pinpoint the problem.
My question is: How can I tell if the vibration is coming from the axes, transaxle, clutch . . .?
Thks - Mark
Old 01-05-2005, 11:16 PM
carguy83 carguy83 is offline
Send a message via AIM to carguy83
Re: Finding a vibration in the front
uhh... take it to a shop that does free estimates
1995 Gold Saturn SL2 -- RIP May 05
1991 Blue Subaru Legacy Wagon -- RIP Aug 05
1995 White Mazda 626 DX -- RIP Feb 07
1991 Black Volkswagen Jetta Carat -- Current
Old 01-06-2005, 12:28 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
http://www.saturnfans.com/photos/sho...p/photo/15886/
louder turning left or right? turning the other way should quiet it down.
did you remove the CV joints? wheel bearings? did the vibration start before or after the work was done?
Old 01-06-2005, 01:50 PM
It is louder turning to the right.
I have not done anything with the cv joints and replacing the wheel bearing was my first guess at fixing the problem, not the cause of the problem.
Something else to note: when I had the car in the air it was louder with the wheels on then when they were off. Is this just due to the extra load on the axles?
Right know I suspect the bearing between the intermediate shaft and the axle.
Old 01-06-2005, 06:31 PM
i'm sure the cv joints would click rather than grind. as for the weight on the axles i'm not sure about that. what would make you suspect that bearing? when was the last time you had everything lubed up?
Old 01-06-2005, 06:53 PM
Roadkill Roadkill is offline
Send a message via Yahoo to Roadkill
I had a wheel bearing go out on my 95 SL2. It didn't have a vibration, just a grinding noise. Oh, the bearing was on the right front. The car had 150,000 on it when the bearing went out. I'm surprised that I didn't have wheel bearing issues sooner. The wife loves taking corners on two wheels. It may be multiple problems. Check the tires for possible tread separation and proper balance. They could just be adding to the problem. Good Luck!
Old 01-06-2005, 11:28 PM
the outside wheel turns faster then the inside wheel on turns, therefore, if the noise is louder on right turns, 99% of the time the problem is on the left side.
what did you replace on the left side? also, check trans fluid.
i forgot to ask - this is audible vibration, mechinical vibration or both? - anything lining up with the chart?
Old 01-12-2005, 12:13 PM
bwright138 bwright138 is offline
Stupid I know... But have you gone through and tightened EVERY bolt on your suspension? Bump-stops intact? My first guess would be metal on metal friction somewhere in the suspension.
